colour of vics plug??
Joey's mx
Post by Joey's mx »
Hey can someone tell me what colour the plug for the vics solenoid is?? Also are all the solenoids the same??(can the prc solenoid be used with the vics setup+wirring??)
Joey's mx
Post by Joey's mx »
this is for a 94 dohc (b6ze)
Joey's mx
Post by Joey's mx »
Can anyone help me out??
Tunes67
Post by Tunes67 »
Heh.. tell me where the plug is and when my car is out of the shop (today or tomorrow) I will look and let you know.
Tunes67
Joey's mx
Post by Joey's mx »
it is beside the fuel rail(passenger side) you might have to follow the vacuum lines form the vics around the back of the intake manifold to the solenoid..it should be either green, white or brown!!! Again you will have to follow the vacuum to know which is which!! I really appreciate it..Thanks!!!
Tunes67
Post by Tunes67 »
No sweat man.. and the shop just called.. my car is done.. should have a post back here for you in a couple of hours (heh.. test drive ya know)
Tunes67
Joey's mx
Post by Joey's mx »
Cool thanks again....hope she runs good!!!
Tunes67
Post by Tunes67 »
Well Sweetness is back on the road.. shop didnt time her very well and I will have to adjust that and the idle.. but the power is good and the idle is smooth. I did check on the VICS solenoid placement. I was able to eliminate the brown solenoid. From looking in the manual (pg F1-110) at the placement of the solenoid, I would say it is the green one. I'd bet on it truthfully.. I just wouldnt bet a lot ;) Hope this helps you man.
Tunes67
Joey's mx
Post by Joey's mx »
Cool it sure does thanks alot.....really appreciate the help...good luck with the timing and the idle!!
