Washer jet lights?
Washer jet lights?
How are these things? Legal? How are the ones on Ebay? Are they easy to install, and like good quality?
- mitmaks
on mx3 stock hood, kinda hard to install(tight spacing) and theyre illegal, but depends on local cops
- mitmaks
you have to have small fingers since you gotta remove stock ones, small space, you can figure it out
the white ones are completely legal in most states... green or other non emergency colorsy cops usually won't bug you for.
ProjectMx
My BP and AWD build thread
Cardomain
93 Mx-3 GS with bp and GTR AWD system
93 Escort GT daily driving
Cardomain
it's really intuitive, open the hood, flip up the edge of the insulator and the back of hte nozzles are held down by clips, use a pair of needle nose to pop the stock ones out, then put on the new ones, again use needle nose pliers to turn the bolt on. It's a tight fit but it's doable.
I know they have been around for a while but I still don't get the point of those little lights...what do you guys think?
eh
eh
- mitmaks
rice..... dont do it
Don't forget that putting them in is one thing - wiring them so they light up might be another. They won't come with everything you need, you'll probably need cable, lugs, a switch, cable ties, etc.So its not impossbile to intall right? Even for a total total novice? Do they come with everything I need
- Kokiriwave
I've seen these on hondas......they looked terriblerice..... dont do it
i must agree..
I want MAZDASPEED!
MY WEBSITE:: http://kingmx.net
- TonioDLR
Ahem!!! Ok look if you're gonna do it. Do it! and if you do it put it on a switch! On when you're parked. Off when you're driving and during the day. I had a hard time getting these bab boys on there but it was just for replacing the nozzles MAINLY I figured what the hell and wired in a switch and presto. ON / OFF .
![Image](http://www.geocities.com/toniodlr/ivana_mini.jpg)
Before you criticize someone, you should drive a mile in their wheels. That way, when you criticize them, you're a mile away and you have their wheels.
