Fog light yellow Reflectors
- Pedro_mx3
my Fog lights have yellow Reflectors an i hate them, do any models of this car have normal silver 1's cause i bought some nice high brightness blue/white bulbs an all i get is brighter yellow. if not is there a way to modify the starndard 1's?? cheers in advance for any input. thanks
I'm not worried about the bullet with my name on, Im worried about the one that says 'To Whom it may Concern'....
Make a Donation, Keep Mx3.com Alive!!
1991 V6 K8 -- My baby, i miss her... On her way to car heaven... <3
Re: Fog light yellow Reflectors
I just replaced mine with some small 100 watt driving lights. Bit of a fiddly job but well worth it I reckon. I used a long bolt and bolted the light horizontally back onto the inner guard and used some strap to support it back down onto where the fog bracket screwed down onto the lip. I found you have to remove the front lip to get the fogs out but then you can put the lip back on and install the driving lights at your leisure. I haven't got any pics yet - just did it on the weekend.
- Pedro_mx3
nice, i have some micro, cruise-lights at home as it happens, if u could post some pics that would be great. im thinkin thats what ill do. jus wanted to try an keep it in the stock lights
I tried to keep it in the stock lights too, even looked at mounting the new lights into the OEM housing, that would have been best so I could keep the shroud and brackets, etc.
In the end I just gave up and removed the fogs and brackets completely. I'll take some pics and you can see how mine turned out.
Pics. These are 100 watt H1 lamps.
<img src="http://optimalimpact.net/eunos/temp/sp1.jpg" alt=" - " />
<img src="http://optimalimpact.net/eunos/temp/sp2.jpg" alt=" - " />
<img src="http://optimalimpact.net/eunos/temp/sp3.jpg" alt=" - " />
This one is looking up from under the car, front of the car to the right. Thats the spotlight bracket with a 1/4" bolt going back to the frame. You can see where the strap goes down onto the lip where the OEM bracket screwed on.
<img src="http://optimalimpact.net/eunos/temp/sp4.jpg" alt=" - " />
I think they look a lot cleaner and neater than the fogs - next I'll need some new indicator / parker lights!
Those look nice in there. Cheers.
I just took my fogs apart and smashed the yellow lens inside of 'em, they look chrome inside now.(but i don't recommend this)
Does anyone have a good "how to" for fixing fog lights to the smallest holes im my type of bumper?? (click link below for my car)
