Passing Aircare with KLZE
Anybody have any experience either good or bad of getting through BC Aircare with a KLZE?<p>thnx
- monstar-mx-3
Re: Passing Aircare with KLZE
Mine passed with no problem
What was your setup - ecu/vaf etc?<p>And what grade of gas did you use?<p>thnx
Soulflare
If ur running on stock cat and no major engine work other then the swap then there will be no problems at Air Care... ran mine fine both KL03 and KLZE passed no problem.
Soulflare
Pearl MX-3 GSR (SOLD)
Mystic RX-8 GT
Mystic RX-8 GT
So Soulflare you had no problme with running rich giving too much HC because of the K8 ecu + JE50 VAF + KLZE setup?
Soulflare
Oups missed this post... no i didn't have any problems with aircare with either of the engines... and I was running on the K8 ecu/vaf with no EGR hookup for the ZE engine either. Didn't remember the numbers tho for the report.
Soulflare
Mystic RX-8 GT
Mystic RX-8 GT
