Yeah i have the same trouble, given with both have G tranies. 2nd gear syncro doenst like over 6500. its annoying.Originally posted by nvrsrndr:
you are absolutely right about the clutch and lightened flywheel. I got my fidanza and my car shifts like butta. usually I dump at 4-5 grand. One problem I am having though is that my tranny won't let me switch from first to second when above 6500 rpm on my klze unless I double clutch. In away that's okay cause 2nd pulls harder than 1st.Originally posted by torpedan:
Yeah suspension makes a big diffrence but i would suggest a good aftermarket clutch with a lightened flywheel. you would be suprised how this changes launchingOriginally posted by Nd4SpdSe:
my problem is hopping, its actually hard to not make my car hop isntead of spinning...
1st is always so short
