Can you Turbo 1.8 L v-6???
Hi i was just wondering if i could turbo this motor.... and if i can ... what size turbo should i get? what kind? and where? Sorry for all the questions :p
Guest
Re: Can you Turbo 1.8 L v-6???
I cant answer your questioin but hat you should do is run a search using the search function at the top. Theres alot of info in there regarding turbos. I think you'll find it to be a little more costly then its worth.
Yes the K8 can handle a turbo. I don't know the max psi it can handle, but I heard it's around 8psi. A t3 turbo should do fine. If you wanna go really innexpensive, you can go to a junkyard and find a turbo. They're relatively cheap ($50 around here) and then with a simple rebuild they should be fine.
~Ryan~
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
