how would you make a mold of headlight lense?
thebox
Post by thebox »
i need an idea here: i'm going to make a mold and fiberglass a piece that is the same size/shape as the lense of a stock headlight. what i have found on the internet so far is helpful, but i have yet to find something that sounds like it would work for this particular job. how would the people skilled in fiberglassing, etc. do this? i have several ideas but i don't think they are good.
1992 MX-3 GS
KLZE - Fidanza Flywheel - CM IIR Clutch - Millenia IM - UR Pulley - IM Spacers - KL36 ECU
fry_81
Re: how would you make a mold of headlight lense?
Post by fry_81 »
what do you have planned? are you doing a headlight conversion of some kind?
1994 5spd GS Parts Car For Sale 800obo. e-mail for details. fry_81@hotmail.com
Sam Baker
Post by Sam Baker »
well.. i've only started to play around with molds, but i know u can use this rubber-like stuff (that you cover the piece in and pop off) or you could make one out of clay, which is harder. you'd probably have to make 2 sides (for inside and outside) and put them together. would be cool i guess, but why make the housing out of fiberglass? planning on making it custom-shaped?
92 Autozam AZ3
MX3-Freak
Post by MX3-Freak »
I thought about doing this...Was gonne go for the acura look, and just cut holes in the fiberglass mold. What I always did when trying to copy something in fiberglass (that I wanted to keep) was just cover the surface lightly with vasaline. Then *lighlty* tap the mat to the surface, and paint the outside of suface. Once dried, I just poped it off, cleaned the inside with a solvent (to remove all petroleom) and put a coat os two on that side.
It may not be the "correct" way, but it has always worked for me...
Stock 1995 RS - Creek Blue
Car Meanins:
mx-3xplosiv31
Post by mx-3xplosiv31 »
another way is to get plaster of paris, mix some up in a tub (something you don't want to keep clean), then push the lense down into it, far enough to get the entire piece, but not too far or the lense will be stuck to it. Be sure to use some sort of release compound on the lense, or it won't come out of the plaster. Once the plaster dries, pull out the lense, and you have a durable mold that you can lay fiberglass into, that will be smooth on the outside, so you don't have to do a lot of finish sanding on it.
Aaron
thebox
Post by thebox »
Aaron
that is exactly what i was thinking of doing, it sounds like an easy way to make a good mold... i just wasn't sure about it. the plan is to build exactly what was said above, acura integra (1994+) style headlights using hella 90mm units that i already have. it is going to be awesome.
1992 MX-3 GS
thebox
Post by thebox »
i only need to copy the outside of the lense, making it the same external shape is the only thing i need to do :D the entire housing won't be fiberglass, only the "face" of it.
1992 MX-3 GS
Sam Baker
Post by Sam Baker »
hehe nvm.. read u wrong. making a lense would be an awesome project, because theres a lotta need for this :D and integ projectors WOO sounds good
92 Autozam AZ3
pyromaniac511
Post by pyromaniac511 »
CRAP!!! :rant2: another of my mods being done by others. Howerver im putting integra lights in the car, I think halo h.i.d. Car goes in friday, ill get some befor pics up on my string.
it's better to be pissed off then pissed on
mb quart component sets 6 1/2 (front & rear), cobalt 200 x 4 rms amp, 2 12" obcon subs in vented box. body kit in progress.
all show, no go.... so far
MX-3 Caper
Post by MX-3 Caper »
Just to understand this correctly, are you using the fiberglass for the whole lens? Or is it a cover over the original lens?? :shrug:
Aaron
96' 1.6 DOHC
pyromaniac511
the integra headlight is 2 seperate lenses, im going to mold them into the car, when they get underway i'll post pics
MX3-Freak
Post by MX3-Freak »
[quote]Originally posted by MX-3 Caper:
Just to understand this correctly, are you using the fiberglass for the whole lens? Or is it a cover over the original lens?? :roll: ).
Car Meanins:
mx-3xplosiv31
I was thinking of molding in these headlights
<img src="http://www.rksport.com/image?product_id ... 3&size=mid" alt=" - " />
but I don't know. I can get them for free, a friend of mine is doing a conversion on his 03 cavy to the 02 front end, and then just putting the hella 90mm units in the housings.
MX3-Freak
Post by MX3-Freak »
Would be a lot easier to just put hellas in the mx housing...
Car Meanins:
thebox
Post by thebox »
[quote]Originally posted by MX3-Freak:
Just to understand this correctly, are you using the fiberglass for the whole lens? Or is it a cover over the original lens?? :D i also plan to add a D2S conversion to the mix when the money is right :D
1992 MX-3 GS
Return to “Appearance”
