hood heat mats
hood heat mats
ne one know where i can get the mats (besides the dealer) that attach to the inside of the hood
- papa roached
Re: hood heat mats
why? i dont have them, never did, shouldnt hurt the hood
Re: hood heat mats
You could use Dynamat. They make hood kits and it makes everything quieter.
Re: hood heat mats
Don't use regualr Dynamat. Both Dynamat and Cascade Audio both have products specifically for under the hood to control both sound and heat.
