Originally posted by mx-flow:
Check and compare using this site:
That site is for klze identification. Mine is the kfze, and I found out it is the right engine. Thanks tho.
wrong engine?
Re: wrong engine?
yes...My intention was that you discard the idea that you have a klze and work on the other posibilities in your list...
Great
Great
Compact Gladiator
"Do not follow the path, instead; go where there is no path and leave a trail"
WWW.GEOCITIES.COM/NEWFLOW81
Re: wrong engine?
Ummmmm. If you read the rest of the post, he never thought it was a KLZE. He had K8 heads with a KF block. He just wanted clarification if it was indeed a KF.Originally posted by mx-flow:
Great
Re: wrong engine?
Great
I got that right, sorry!. Probably I'm not making myself clear enough. He can use that website as a reference to compare engines and see that parts in his engines are going to be alike and diferent in the klze series as well. JUST AS A REFERENCE (a little knowledge won't kill know one)
Great
Compact Gladiator
