thing is you gotta use teh K8 flywheel because the millenia dont have one, it has a flexplate because its an autoOriginally posted by IanL:
I would say stick with the Millenia flywheel, as long as its suitable to take the clutch - I'm willing to bet there's no-one who's tried a lightened flywheel on a KJ, and you are doing enough risk-taking alreadyOriginally posted by Mariusz:
Should I use stock flywheel from K8(MX-3) or KJ(Millena) ?![]()
KJ 2.3
- papa roached
Re: KJ 2.3
Re: KJ 2.3
My error - didn't know about drive plates for ATX. Maybe a KL flywheel would be more suitable?Originally posted by papa roached:
Extra thick soundproofing in the boot (trunk) to quieten my stainless steel exhaust system
TsiMiata
Re: KJ 2.3
If it was me I'd be putting an aluminum flywheel on there. Lighter is better in my book. Using the K8 flywheel gets you a few pounds lighter and for him it would be free.
91 Eagle Talon Tsi AWD *RIP*
Re: KJ 2.3
I know that's true with an Otto Cycle engine, but this is a Miller Cycle - huge valve overlap - I'm skeptical that a lightened flywheel will be good.Originally posted by TsiMiata:
mmx01
Re: KJ 2.3
I've called to them today, they've promised to reply my about this topic till sunday. I have hope that the price won't kill me.
Dreaming about K8 to KJ swap :]
TsiMiata
Re: KJ 2.3
There isn't more overlap on a miller. The intake valve is open longer- while the exhaust valve is closed. It doesnt run like a 68 camaro with a crazy cam. It's a luxury car engine, which is all about being smooth.Originally posted by IanL:
mmx01
Re: KJ 2.3
I have some doubts about this KJ swap, I heard that there is a lot of problems with spare parts.
So the swap it self is doneable but what with car exploatation ? Spare parts for SC and others ? Does anyone knows sample prices of the weak engine parts ?
TsiMiata
Re: KJ 2.3
From everything I've heard the KJ is very reliable. I have a friend thats a parts manager at a mazda dealer. He told me the KL 2.5 liter millenias had much more warranty work than the KJ powered cars.
mmx01
Re: KJ 2.3
So it's basically better than a ZE ?
Also what is the diffrence between KL-ZE straigth and curved neck ? besides the shape ?
Does someone knows this company ? : http://www.a1jdmengines.com/home.htm
PS. most of peoples are switching the distributors between ZE and K8 during swap why ? If you can buy a engine with distributor why don't use a stock one ?
Re: KJ 2.3
The straight neck usually interferes with the brake reservoir on LHD cars, the curved does not.Originally posted by Mariusz:
You have already had that information in this threadmost of peoples are switching the distributors between ZE and K8 during swap why ? If you can buy a engine with distributor why don't use a stock one ?
mmx01
Re: KJ 2.3
Yes, but I received a picture of an engine where the distributor is complete with the high voltage wires. If the distributor is complete should I or should I not switch it ? Probably not
Re: KJ 2.3
If it is "complete", fine, but count the H V wires - if there are seven, it has a separate coil and igniter.Originally posted by Mariusz:
Yes, but I received a picture of an engine where the distributor is complete with the high voltage wires. If the distributor is complete should I or should I not switch it ? Probably not![]()
mmx01
Re: KJ 2.3
I will check number of HV cables, and what means reservoir interfaces ? There is only cable for brake fluid level.
Re: KJ 2.3
Sorry, technical term. Interferes, not interfaces - it means it comes into contact with itOriginally posted by Mariusz:
mmx01
Re: KJ 2.3
OK, so which one should I choose for replacing my K8, curved or straigth ? I have LHD like most europeans
K8 has a curved one
