Chance IAC
Chance IAC
I have a klze and the iac isn't working properly, can I chance the one from the klze with the one from the k8 that I have lying around?
thanks, Bastian
thanks, Bastian
17 inch bba racings rims, apex lowering springs, laser muffler, boost steering wheel, mazdaspeed seats, black altezza's, testpipe, oh and a polished klze with an upgraded clutch and a kl36 ecu.
Re: Chance IAC
It's 'change'. 'Chance' is a rough guess or a bet.
The IAC on the KLZE doesn't use vacuum. So it is not the same. If your KLZE throttle body is from a curved neck manifold, your K8 IAC can be swapped over if you find a vacuum hose to tap into to get to the K8 IAC. If your ZE throttle body is from a straight neck manifold, the K8 IAC will not swap in no matter what you do because the IAC and coolant lines are on the wrong side.
Re: Chance IAC
If you are using your stock K8 throttle body, you can only use a K8 or millenia IAC valve assembly.
If you are using the KLZE throttle body, any KLDE throttle body from a Probe GT, 626 ES or MX6 LS will swap on.
Or you can just remove it, and block it off. It isn't needed. It only helps with the idle when cold.
DONATE TO MX-3.COM
DONATE TO MX-3.COM
- papa roached
Re: Chance IAC
so my millenia TB with everything on it should work just fine?
- Zoso124
Re: Chance IAC
Mike Evans
Gone:
Gone:
Re: Chance IAC
Or when the air conditioning is used.Originally posted by Gro Harlem:
Re: Chance IAC
Sorry for the spelling error, I must have been sleeping or something like that. I changed my eunos800 iac with a stock k8 but now the engine is really stuttering at 2000rpm, I'm not sure the iac was working properly before, so I'll guess I'll have to chance them again.
Bastian
Bastian
Re: Chance IAC
As I said in my post, it all depends on which side of the TB is on. There are KLZE TB's with the IAC on the same side as the K8. Not many, but they're out there. There was one on eBay a couple weeks ago.Originally posted by Gro Harlem:
Re: Chance IAC
The iac is on the same side as it was before.
