ZE
lakersfan1
Re: ZE
You could search, but.......you CAN use the K8 ECU, but it will run like crap. But it'll get you by till you get the money for the ZE ECU.
Nallboy
Re: ZE
It depends on whether you want it to run or not.
There are a couple different combos that seem to work well. Most common is ZE ECU and stock K8 VAF.
There are a ton of posts on this.
'93 GS sporting 31 ZE, 36 ECU, Millenia IM & TB, Beefed up tranny, Fidanza FW, CM Stage II-R, Al UDP, HS Headers, MF Hi-Flow CAT, 2.5" Piping, CAI, MGC Wires, MS Mounts, B&M SS, Bronzoils, SS B & C Lines, Brembos...more.
Oh yeah, I have a stock ATX 92 RS too.
"Everyone wants to live life in the fast lane; I have more fun weaving through traffic."
Re: ZE
k8 ecu works fine with k8 vaf
ze ecu works fine with k8 vaf
killerpickle
Re: ZE
dont forget the 2.5 (a-spec) ecu, and 2.5 (a-spec) vaf
Tom Alexander
Nallboy
Re: ZE
Yeah, I just decided to let this guy search for himself after I read some of his other posts.
Re: ZE
I think this should read:Originally posted by DavidOS:
K8 ecu runs rich with the K8 Vaf;
K8 ecu runs best with the KL02 vaf off a probe
KL31 or KL36 runs best with the K8 vaf
<small>[ June 03, 2004, 09:49 AM: Message edited by: J Love ]</small>
93 White MX-3 "Ebay special"
94 Green 626 V6 5-speed "family car"
94 Mazda B2300 SE "project turbo truk"
Re: ZE
Re the 2nd line, I think the ZE ECU actually expects a "K8" VAF, so that's what it works best with.Originally posted by J Love:
ZE ecu runs best with the KL02 vaf off a probe
Extra thick soundproofing in the boot (trunk) to quieten my stainless steel exhaust system
