Wait a minute, I thought V6 MX3s had 170ft Torque!?
Guest
Post by Guest »
Someone in this forum told me they only have 120. I thought they had more than that.
Is it true that V6 MX3s have 170ft Torque?
Nallboy
Re: Wait a minute, I thought V6 MX3s had 170ft Torque!?
Post by Nallboy »
I think that would be the KL-ZE
'93 GS sporting 31 ZE, 36 ECU, Millenia IM & TB, Beefed up tranny, Fidanza FW, CM Stage II-R, Al UDP, HS Headers, MF Hi-Flow CAT, 2.5" Piping, CAI, MGC Wires, MS Mounts, B&M SS, Bronzoils, SS B & C Lines, Brembos...more.
Oh yeah, I have a stock ATX 92 RS too.
"Everyone wants to live life in the fast lane; I have more fun weaving through traffic."
mitmaks
Post by mitmaks »
did you read that it has 170tq or you "thought" cause thoughts arent always right lmao. its ~115tq
babyblueMX3
Post by babyblueMX3 »
and klze's are 160 of torque
RIP 400whp ZE-T MX-3
Gro Harlem
Post by Gro Harlem »
omf! when is the idiocy going to end?
:rant2:
DONATE TO MX-3.COM
mitmaks
Post by mitmaks »
its 195 tq i believe on klze
I belive tq depends on if you have the Millenia or the Mx-6 cams
babyblueMX3
nah i saw i dyno it wasn't near 195.....
and what Nd4SpdSe said is also true..
Nallboy
Post by Nallboy »
Yeah I've seen tq range from ~160 to ~175 on the ZE. Depends on a few factors. But there's def. not that much in the stock V6.
Gro Harlem
KLZE makes 22.8 kg/m, converted that is about 164 ft/lbs at 5500rpm
DONATE TO MX-3.COM
Guest
Post by Guest »
I am talking about a 93 V6 MX3. Not no MX6 or 95 MX3. I just thought I would tell you guys this because someone told me that MX3s have 170ft Torque. Not 120!
Now can I get some comfirmation that my 93 MX3 has 170ft Torque?
killerpickle
Post by killerpickle »
no. It does not. Not even close. ALL stock v6 mazda mx3's have roughly 115 ft lbs of torque.
Tom Alexander
babyblueMX3
there you go.....and I'm not sure where did you get the idea that 95 engines were different than the others
Nallboy
Post by Nallboy »
:confused2: I don't know where you get your info, youngin, but it's not very good. The stock V6 is no different, and def. nowhere near 170 ftlb tq.
Gro Harlem
yup, how do you expect a engine that is rated at 130hp to make MORE torque when its got such a small displacement?
THe stock torque rating is 115 btw. The 2.5 KLZE doesn't even make 170 ft/lbs stock.
DONATE TO MX-3.COM
Locked
