Wait a minute, I thought V6 MX3s had 170ft Torque!?
Someone in this forum told me they only have 120. I thought they had more than that.
Is it true that V6 MX3s have 170ft Torque?
Re: Wait a minute, I thought V6 MX3s had 170ft Torque!?
I think that would be the KL-ZE
'93 GS sporting 31 ZE, 36 ECU, Millenia IM & TB, Beefed up tranny, Fidanza FW, CM Stage II-R, Al UDP, HS Headers, MF Hi-Flow CAT, 2.5" Piping, CAI, MGC Wires, MS Mounts, B&M SS, Bronzoils, SS B & C Lines, Brembos...more.
Oh yeah, I have a stock ATX 92 RS too.
"Everyone wants to live life in the fast lane; I have more fun weaving through traffic."
- mitmaks
did you read that it has 170tq or you "thought" cause thoughts arent always right lmao. its ~115tq
- babyblueMX3
and klze's are 160 of torque
RIP 400whp ZE-T MX-3
omf! when is the idiocy going to end?
![Rant2 :rant2:](./images/smilies/rant2.gif)
DONATE TO MX-3.COM
DONATE TO MX-3.COM
- mitmaks
its 195 tq i believe on klzeOriginally posted by babyblueMX3:
I belive tq depends on if you have the Millenia or the Mx-6 cams
- babyblueMX3
nah i saw i dyno it wasn't near 195.....Originally posted by mitmaks:
and what Nd4SpdSe said is also true..
Yeah I've seen tq range from ~160 to ~175 on the ZE. Depends on a few factors. But there's def. not that much in the stock V6.
KLZE makes 22.8 kg/m, converted that is about 164 ft/lbs at 5500rpm
DONATE TO MX-3.COM
DONATE TO MX-3.COM
I am talking about a 93 V6 MX3. Not no MX6 or 95 MX3. I just thought I would tell you guys this because someone told me that MX3s have 170ft Torque. Not 120!
Now can I get some comfirmation that my 93 MX3 has 170ft Torque?
no. It does not. Not even close. ALL stock v6 mazda mx3's have roughly 115 ft lbs of torque.
Tom Alexander
- babyblueMX3
there you go.....and I'm not sure where did you get the idea that 95 engines were different than the others
![Confused2 :confused2:](./images/smilies/confused2.gif)
yup, how do you expect a engine that is rated at 130hp to make MORE torque when its got such a small displacement?
THe stock torque rating is 115 btw. The 2.5 KLZE doesn't even make 170 ft/lbs stock.
DONATE TO MX-3.COM
DONATE TO MX-3.COM
