White smoke while in 1st gear
greatunicon
Post by greatunicon »
first, THX everyone answered my Wuestion before, really help me alot....<P>My 1.8 always have while smoke when i put in to 1 st gear...but no smoke in high speed or stop<P>i know it is a common problem in K-engine,for the head gasket problem, is it??<BR>i always need to some oil every time of full gas.<P>i know to fix it will cost me alot. is that ok , i am keep adding oil, will the engine go more worse??<BR>do i have to replace the gasket???<BR>how much it cost??<P>help a beginner of MX-3
a
MI-Archangel
Re: White smoke while in 1st gear
Post by MI-Archangel »
hey man dont worry to much bout it i had same problem after i raced alot FIX IT my oil gaskets burst when i was racing frying my distrubtor so fix it or risk paying more luckly mine was under warrenty or i woulda payed 1300 so fix it now buddy
greatunicon
THX,for reply,<P>now i really don't have $$ to pay for changing gasket, so all i can do just keep adding oil. Will my engine die or cause more problem? at least, what can i do make the engine losing less oil in cheap way??<P>Please help... :( :(
a
mazdaspeed002
Post by mazdaspeed002 »
Letting the problem go on is a bad thing. White smoke is usually not related to burning oil, its usually condensation thats white smoke(water burning). Blue smoke is oil. Does the car smoke than after a while go away or does it smoke constantly? My guess is its most likley rings or valve seals, but hey what do i know, im only a hobbiest. Definatlley get it checked out. I'd jsut replace the motor totally. Its better to spend $800 now and have a car then to spend $1200 later when you're broken down 100 miles away from your house. Good luck.
greatunicon
hey, mazdaspeed002 what is replace motor???<BR>is that rebuild engine??? and 800us or ca dollar?<P>i usually, have white smoke when force to start runing in 1st gear.. no smoke in stop or after 1st gear... if it is not burning oil, where does the oil losing?? my oil level always is low.<BR>i have really no idea about my Engine.<P>really THX for help!!! :) :)
a
MI-Archangel
just keep filling with oil and put moter medic in oil
quinn_seipp
Post by quinn_seipp »
white smoke can be the anti freeze as well... we had a semi that would pour out the white smoke because it was burning the anti freeze [img]shrug.gif"%20border="0[/img]
130 hp and 1000 horsepower strong, ;)
