sub placement
sub placement
i was wondering if anyone had a better way to situate sub ? like facing up, aginst the back seat facing rear, in rear facing back seat, or any others ? just want to know the best way thanks
CTC Racing
92 1.6L
93 323 Tranny, ACT clutch, Exhaust, cold air intake, MSD Blaster 2 coil, MSD 8.5mm super conductor wires NGK V-power platinum plugs,engine dress up,custom interior(almost done), GS front bumper, GS 5 spoke wheels Painted white.
92 1.6L
- Typhoonk
Re: sub placement
in smaller hatchbacks - against the seat facing back. Gives the sub the most space to play 'into'.
But right now I have mine fibreglassed and MDF'd into the drivers side panel facing the passenger side. Works well for me. Just got to finish it so it looks good. Once step at a time.
But the best way to find out is to experiment, give it ago every which way and see which one you like![Laugh :laugh:](./images/smilies/laugh.gif)
PM for info
PM for info
- papa roached
Re: sub placement
in my RS i had 1 10 in a box, and it sounded best set against the back of the car facing forward, but like he said, try different things to see what you like
Re: sub placement
A bold idea witch I'm going to attempt next year : putting the subs in the middle back seat. It's gonna be a big mod, but I'm sure it'll get done.
