[ 14 posts ] |
Gas/fuel meter doesn't work
Author |
Message |
WhiteFinish
Joined: April 03 2006, 9:48 AM Posts: 1631 Location: Netherlands
Why would a gas meter not work anymore ? The light when I'm low on fuel still works. But the meter always indicates full (i wish it was !!)
_________________ Just another Mx3 freak
Feedback topic: Click
Worklog Worklog click
February 09 2012, 3:57 AM |
RobMinhas
Joined: November 05 2011, 8:32 PM Posts: 1614 Location: Calgary, Alberta
 Re: Gas/fuel meter doesn't work
I have a semi related question here.....
Ummm..... do all MX3s have fuel lights that come one when gas is low? I ask because mine has never gone off before....
Daninski wrote: This is my MX3. There are many like it, but this one is mine. My MX3 is my best friend. It is my life. I must master it as I master my life. My MX3, without me, is useless. Without my MX3, I am useless. I must fire up my MX3 true. I must drive straighter than any Honda driver who is trying to own me. I must own him before he owns me.
February 09 2012, 4:11 AM |
Joined: May 25 2002, 2:01 AM Posts: 11209 Location: CFB Val-Cartier, Quebec, Canada
You sure it's the gauge and not the sending unit in the tank? I've never replaced the gauge, but I've had to replace the sending unit before, maybe even twice, but the low fuel light is independant from the gauge needle, that seems to be a different sensor.
_________________ 1992 Mazda Mx-3 GSR - 2.5L KLZE : Award Winning Show Car & Race Car ['02-'09] (Retired) 2004 Mazda RX-8 GT - Renesis Wankel : LS3 Coils, BHR Mid-Pipe + Falken RT-615K 245/40r18 2011 Mazda Mazda2 GS - 1.5L Manual : Yozora Edition (1 of 500) 2003 Nissan Xterra SE - 4x4 Supercharged : 2" Body Lift, 4" Suspension Lift & 33" MTR Kevlar 2001 Nissan Frontier SE - The Frontrailer : Expedition/Off-Road Trailer Project
February 09 2012, 4:29 AM |
MrMazda92
Joined: October 08 2009, 5:35 PM Posts: 5199 Location: Eugene, OR
I'd test the sending unit first as well, I've had several fail in other cars.
_________________ '12 Challenger R/T Plus w/ STP - Brilliant Black - 3.92 w/ Limited Slip, Shorty headers, SkipShift delete, Clutch Delay Valve delete, Hurst STS, RAM Clutch Adjuster, Boss 338s/Sticky Nittos, Tuned
92 G4S 5 spd - KL, MegaSquirt, Coilpacks, Gone: VAF/Power Steering/Air Conditioning/EGR/ABS/Auto Seatbelts/etc, 5 lugs, Speed6 brakes, FD wheels, wiretuck, progressive rate coilovers w/ tender springs, modified shorty headers w/ custom collector, AEM WB, 2.5" straight
February 09 2012, 4:51 AM |
WhiteFinish
So where could i find the sending unit ? How does it look like?
I've replaced the stock pomp with the walbro, perhaps I messed up the sending unit ?
February 09 2012, 8:09 AM |
MrMazda92
Did this happen when you were modifying your gauge cluster? The fuel pump attaches to the sending unit, I haven't personally had a reason to take mine out yet, but I would assume that it is under the rear seat with the pump.
February 09 2012, 1:10 PM |
WhiteFinish
Uhh.... it happend some years ago.. can't really remember when.
I just went to a gasstation when the light came on.
February 10 2012, 3:51 AM |
MrMazda92
Hmm, well that's still not too bad... when my light is steady on I have almost exactly 3.2 Gallons left!
February 10 2012, 6:40 AM |
The sending unit is in the gas tank, accessible under the rear seat. It looks like this:  That's for a 323, but nearly identical. That black square box is your floater.
February 10 2012, 11:56 AM |
mikeinaus
Joined: November 02 2009, 4:03 AM Posts: 1751 Location: Vancouver, BC
you can test the sender by putting a volt meter onto the 2 leads (screws) that the gauge needle uses for signal. with the pump assembly removed from the car have someone move the sending arm up and down while its attached to the harness and the ignition on(car off). voltage ouput between the leads should move up and down with the lever, if not replace the sender, if it does replace the gauge...
March 07 2012, 11:58 PM |
WhiteFinish
Thanks, for the tip I've replaced both
March 08 2012, 6:22 AM |
WhiteFinish
Nd4SpdSe wrote: The sending unit is in the gas tank, accessible under the rear seat. It looks like this:  That's for a 323, but nearly identical. That black square box is your floater. Super old topic bump. Where did you find this sending unit? Did you get it via Ali Express? searching on what key words?
February 25 2018, 6:13 PM |
I got mine from Mazda directly....but we're going back many, many years.
March 15 2018, 2:46 PM |
March 15 2018, 2:49 PM |
[ 14 posts ] |
Who is online |
Users browsing this forum: No registered users and 1 guest |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum
