View unanswered posts | View active topics It is currently June 06 2020, 12:51 PM
Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
 A Proper Big Brake Kit
Post Re: A Proper Big Brake Kit
I have been through this in every concievable permutation and from every possible direction for over 2 years now.
There is no need for anything more than the Miataspeed rears. they work great and their readily available.
As AaronTietje explained, the MX-3/323/Protege caliper is designed to bolt directly to the spindle, unlike other cars on which the caliper bolts to a bracket which in turn bolts to the spindle. Because of this the stock mounting points for the front calipers are positioned so that they will be in the way...unless you move the caliper away from the center far enough to clear the mounting tabs altogether. Which is why any aftermarket big brake kit will use a 13 or 14" rotor.
The other issue is wheel offset. A 4 piston caliper is going to hit the wheel if you use a rotor with the stock hat height because it's going to be wider than the stock caliper. A rotor with a much taller hat will contact the spindle. The answer to this problem would be to use a wheel with a much lower offset than ours...which again Aaron had to do for his F1 calipers...and cost a lot of money.
I did the Subaru 2 piston upgrade for about $800 and I will say with confidence that this is the ONLY way to do any sort of decent upgrade to the front brakes that doesn't require a larger wheel and a lot of money. Now that I have larger wheels and the 323F spindles I could do a much larger upgrade but it would cost me another $6-700.
I encourage you to try, but I couldn't find a way..and I'm no dummy.
Read this...viewtopic.php?f=20&t=71801&hilit=mazda+brake
June 24 2012, 12:53 PM
True True True
June 24 2012, 2:29 PM
i will for sure be doing the 04 miata rear caliper upgrade but from your guys experience, was it hard?
June 24 2012, 2:34 PM
Profile YIM
It literally could not be easier.
June 24 2012, 10:58 PM
cool im ordering what i need right now
June 25 2012, 2:06 AM
Profile YIM
The only thing I would caution about the Miata rear brake setup is that the E-brake cables are a bit too long for the new position of the calipers. You should try to figure out a way to move the mounting point of each cable back about an inch or two just to keep the cable from having to make a tight bend right by the caliper.
A piece of metal with two holes in it to elongate the mounting tabs at the trainling arm and under the body is all it would take.
June 25 2012, 10:17 AM
Rx7 caliper hits the rim, tried and failed.
4 pot willwood, sucess. Had these on for years now so all the parts are out there!
2.5 Ze straight neck, blitz intake, mazdaspeed engine mounts, fidenza flywheel, CM II Clutch, KL-36 ecu, Magnecor 8mm Leads, Battery Relocation. Hotshot headers, 2.5 mandrel bent stainless exhaust, hi-flow cat, Speed hut dials, custom coilover set up. Custom willwood big brake conversion.
January 04 2013, 3:36 PM
