| Author |
Message |
Ryan
Joined: April 07 2008, 1:06 PM Posts: 7156 Location: Manitoba
 Re: Official Transmission Swap Information
Okay, I took some time out of my day and went to Mazda and copied all the gear ratios from all the relevant models.
I'll update the first post now
_________________ Now with Moderator power!
Black '93 BP RS - RIP Green GS - Sold Black GS - Summer DD/Race car - Fancy KLZE Red GS - K8-ATX -> MTX-KLDE - Winter DD. Well behaved. White GS - Rusty. Parts. ____ GS/Miata - to be built and kept as a summer/sunday car! Feedback
I'm a JYA. Junk Yard Addict.
| November 06 2010, 2:02 PM |
nolig2278
Joined: July 27 2003, 2:01 AM Posts: 409 Location: miami
 Re: Official Transmission Swap Information (Update 06/11/201
where can i find a flywheel that will fit a bpt with G series transmission? a cheap one as i do not want to spend the funds for a light one?
advanced auto parts only lists the sohc flywheel.
Thanks
_________________ 94 RS to BPT 2.5 FMIC BPT-ECU RX-7-VAF 2.5 Exhaust http://www.levinsonltd.com/mx3/
| November 14 2010, 3:41 AM |
grim760
So my mx3's tranny is going out and the estimate I got for a rebuild was $1600 bucks. I can't seem to find a replacement anywhere. It is a 1.6L I4 with an automatic transmission. My question is, is there any interchangeable transmission? I'll even consider changing it into a 5 speed if the price is right. Or if you know any reputable shop that might have my transmission for cheap?
| January 02 2011, 11:29 PM |
nolig2278
do a search on 5sp swap as i believe it will pop right in. they also can be found for $150 to 300 at junk yards.
| January 02 2011, 11:59 PM |
Ryan
atx must be from any sister chassis, B6 engine, IIRC. So, 1.6 SOHC 323 and protege I don't pay much attention to the autos, because they suck.
5 speed swap is found on here, its honestly just a day of work. Gathering the parts is a bit more difficult, might be a day in a scrap yard.
| January 03 2011, 12:51 AM |
grim760
I've called every junk yard within a 50 mile radius and can't find another mx3 anywhere.
| January 03 2011, 11:22 PM |
Ryan
Where are you located?
| January 03 2011, 11:52 PM |
Demonic1
Joined: May 19 2008, 3:54 PM Posts: 302 Location: Ravensdale WA 98051
First off: BP, 92 RS, (had) stock F5M-R. Looks like I'm hunting for a new tranny too. I went to a yard today and they brought out an auto 92 SOHC, but nothing on that interchanged (well duh). I looked at an Escort GT G5M-R trans, and the mating shaft looked longer (plus the whole motor mount didn't look like it'd swap over. The speedo interface looked different too. I was also a little unsure, as I'd heard something about our axles being different? (Splines?) They had a 92 SOHC 1.8 protege, but wouldn't pull it since it was close to closing time.
So, what trannys interchange?
Escort GT (BP) Kia Sephia Protege LX (BP) Protege DX (B8 & B6) 323s?
Also what about the speedos? digital vs. cable?
I've called every junkyard in the south seattle area and haven't found a tranny yet (or overlooked my options?)
_________________ Wings on an MX3? What are you thinking?
| January 04 2011, 1:51 AM |
Ryan
Man.
BP is G series transmission. This is known. digital speedo, and G sized internals, and G axles, etc... so no, BP is a G series. 92 RS is an F series.
People have thrown escort GT axles into the MX without binding, but I wouldn't. the escort GT motor you looked at was either a BP or an 1.9l SEFI bulls--- ford motor.
You're asking questions that are answered in the first post. All B series engine's transmissions interchange.
| January 04 2011, 2:04 AM |
Demonic1
Yeah, I didn't want to throw another 150-200$ at axles anyway. I've already got to get a new clutch (blew a hole inside the bell housing and dumped the gear oil on clutch)
So the G series tranny used different axles (22 spline? or something like that...) The digital speedo was on all versions of the I4 G series trannys? The G internals from the I4 and V6 are swappable (as posted on page 1)
I guess my real question was for the 92 SOHC protege tranny interchange. I'm also asking questions to help get a some information I thought might be lacking.
Do we have a post about which trannys were on which motors/cars?
| January 04 2011, 2:12 AM |
grim760
I'm from San Diego California.
| January 04 2011, 2:51 AM |
Ryan
Just go get BP axles from a Escort or Protege. Apparently they do not bind. They will fit your MX hubs.
It says clearly, even in caps on the first page that all B series engine's transmissions interchange.
| January 04 2011, 11:33 AM |
grim760
So any b series transmission from any year from a mazda or other sister company will bolt on without any problem?
| January 04 2011, 3:17 PM |
Ryan
any transmission from any B series engine, yes. Thats what I meant by this: Quote: Yup. Any B series 4 banger from the 1.3L in Europe, the the 1.8L B8 have the same transmission bell housing, that is, THEY ALL INTERCHANGE.
| January 04 2011, 3:29 PM |
grim760
Sorry for being such a ditz. I just don't want to go and spend money I don't have for something that won't fit. Thanks for the info.
| January 04 2011, 4:21 PM |
