View unanswered posts | View active topics It is currently April 04 2020, 9:22 PM
Reply to topic  [ 13 posts ]
 launching off the line at ---- rpm????
Post launching off the line at ---- rpm????
just wondering really i want to know from the de's and ze's.......no offense to everyone else.......but anyone running DRAG RADIALS....what do you launch at and do you get wheel hop....
-jdMx-3Kid
jdmx-3 KID OF THE Image
VICTORIA RACING
ZE PERFORMANCE IN 915 TX
Kl01-ZE,Kl31 ecu, millenia manifold, ngk plugs, ngk wires, probe tranny/ and clutch (stock), VortecH FMU 12:1, Aeromotive AFPR, Tial .38mm Wastegate w/ 4lbs spring, Walboro 255 pump, AiResearch T4, 3" down pipe, GODSPEED manifold, Spearco Boost Gauges, BF Goodrich G-force drag radials.
14.8 1/4 mile all motor untimed on boost.
May 21 2006, 3:57 PM
Post
I would suggest around 4k to 5k but that is just me you can do a few test in those ranges and see what works the best for you.
May 21 2006, 7:26 PM
Post
in my probe with ZE cams and intake manifold i launched at 4200 right below vris
dohc b6, intake, exhaust, miata cams ready to go in
February 07 2007, 3:16 PM
Post
heh non drag radials you HAVE to launch it below 3000 because you WILL HOP LOL
-hec
February 08 2007, 3:31 AM
Post
i dont hop, i just burn
February 08 2007, 12:01 PM
Post
i launch at 6,000 rpms with either drag radials or slicks but i don;t have a V6. i have the 4cly BP i never had wheel hop unless i launched on street tires.
if i launch below 4000 rpms the car just bog down probly cause its boosted vs N/A.
February 08 2007, 9:54 PM
Profile YIM
Post
I slip it around 2grand and It still spins but it moves. Any higher and my car just spins and goes no where.lol
98 Volkswagen GTI VR6
93 Mazda MX3 KLZE Turbo R.I.P
February 12 2007, 2:40 AM
Post
non radials, K8 and on the street... around 3000 rpm's and still get wheel hop :?
K8 :: 136.8 bhp---160 nm---108.0 whp---118lbs/torque
ET: 15.567 @ 136 kmh (84 mph)
"Racing a Honda is like being in the special Olympics, you may win, but in the end your still retarded."
February 14 2007, 8:19 PM
Post
i lauched at 4000 today and the car span and went nowhere.. i ran a 16 sec run ew lol
-hec
February 17 2007, 4:29 AM
Post
Damn you guys are lucky...i cant launch higher than 1500 RPM and slipping it on street tire...even with my LSD i think 2,500 RPM slipping it was the best i can do.
Now that i am turbo i can't do any launching on street tire, let alone any flooring in 2nd..haha :lol:
March 07 2007, 5:55 AM
Post
launch at around 2000, slip it out kinda fast then floor it, as long as you good some pretty good tires likei had youw ont spin much, it will just fly out of hte hole
March 07 2007, 1:46 PM
Post
dude drag radials.... warm them suckas up and launch high like at 4k.... beautiful kick off the launch....
VICTORIA RACING
March 12 2007, 3:05 AM
Post
drag radials are nice but i like to keep street tires since its a street car and i was drunk when i posted that anyway :P
March 13 2007, 12:40 AM
