View unanswered posts | View active topics It is currently February 16 2020, 5:50 PM
Reply to topic  [ 31 posts ]  Go to page 1, 2, 3  Next
 PERMENANT Distributor ignition module FIX & External
Post PERMENANT Distributor ignition module FIX & External
I just wrote an in-depth how-to based off of information I got off of ProbeTalk. This how-to explains how to use a General Motors HEI module to override your stock POS distributor ignition module. This is a PERMENANT fix to this failure-prone part.
I also outline how to install an external coil in your car w/out needing a KLZE distributor. You simply mod your distributor cap & buy a MSD Blaster coil.
http://www.clubprotege.com/wil/howto/hei/index.htm
Let me know what you guys think, or if you see any errors.
Total cost for the parts to just install HEI module are ~$25 if you buy a new module. Add external coil, coil wire and extra wiring and you are talking about another $35-40ish dollars.
And please do NOT put this in the FAQ! (yet)
October 12, 2004, 11:09 PM: Message edited by: Gro Harlem ]
HEI Only
HEI w/ Coil
DONATE TO MX-3.COM
Added more diagrams
October 12 2004, 10:41 PM
Post Re: PERMENANT Distributor ignition module FIX & External
Oh and if you guys were wondering...I've only put about 300 miles on this setup so far, but I haven't had any kind of idle problems, and no indications that this doesn't work flawlessly. Lots of probetalk guys have been using this setup for a LOT longer with no problems.
Also...in case you were wondering, YES I FEEL A DIFFERENCE! I'd say very significant. I am not one who normally says "i got a hp gain out of my VTEC stickers y0" but I swear installing that Blaster 2 coil and module increased power somewhat. The ZE revs MUCH smoother than before with no hiccups like it used to.
BTW: i'm using NGK V-powers (the proper ones for the klze) and accel 8mm wires. The wires are decent spiral-wound ones...the shorter front-cylinder bank wires are about 200-300 ohms resistance while the rear wires (much longer) have about 500-800 ohms of resistance. FYI stock wries have about 2000-3000 ohms of resistance :(
DONATE TO MX-3.COM
October 12 2004, 10:44 PM
let me say FAQ time! and you are AWSOME! i will be doing this mod soon
October 12 2004, 11:48 PM
Site Administrator
Let me know when to put it in the Faq.
Keep this site alive! Donate!
October 13 2004, 12:18 AM
Nicely done. Maybe the ZE needs a good external coil. Since they did have external coils stock. I know for sure i'm getting one soon :2thumbsup:
Mods:
- ZE, Mike seli 214 intake cams, Ported n polished heads, Interprep valve springs, DE retainers, rebuilt bottom end, toga main and rod bearings, toga hv oil pump, CZT 67mm tb, mbx udp, ported intake mani, SS headers, 2.5inch full exhaust, racingbeat muffler, highflow cat, megasquirt v2.
new toy, 86 TII rx7, JDM S5 motor/turbo, + alot of other goodies
October 13 2004, 12:20 AM
This would work on the K8 aswell, I suppose?
nope-mx3
:: 2001 Mazda Mx-5 Sport // 2013 Volvo V40 D2 Momentum ::
October 13 2004, 9:31 AM
works on any K-series described in the how-to application section.
DONATE TO MX-3.COM
October 13 2004, 4:38 PM
Amazing!!! Well done Gro!!! :2thumbsup: :2thumbsup: :2thumbsup:
Cris
October 13 2004, 5:39 PM
Instead of modding the stock disty cap for the coil tower MBX sells one. From what PTers say its worth the money. Just my 2 cents.
65 shot > V8
October 13 2004, 5:58 PM
Ya, it definitely looks cleaner, but I did that before they started offering those caps.
I had all of the parts to do this HEI thing back in April, installed it & it didn't work. Turns out my wiring was way off. I just got lazy and put it off until this past weekend.
BTW: if you guys wanna buy a pre-modded disty cap u can go to ProbeSports site here:
http://www.probesport.com/mdc04.html
Definitely much cleaner than my cap :werd:
DONATE TO MX-3.COM
October 13 2004, 7:16 PM
nice write up gro..
now somebody should try to find out how to use the 7 nipple ze disty..that would be ten times cleaner :)
RIP 400whp ZE-T MX-3
October 13 2004, 7:22 PM
Thats excactely what i was thinking babyblue :)
But its good to know how to get around the stock distributor if its gets faulty (i just got the dealer to change mine before i bought the car) and never had any problems with it so far :shrug:
1992 MX-3 V6 Z1 Arbet VIII 17 x 8" -35mm Proracing Springs on KYB Sports, Corksport Strutbars, Brembo Cross Drilled & Slotted, Goodridge SS Brakelines, Corksport SS Clutchline, Mazdaspeed Enginemounts & Front arm bushings, All SRD bushings in shifterlinkage and cross member, Pacesetter Shortshifter, KN Conefilter, Custom SS Exhaust, Stereo Oldschool Goodies Denon & Phoenix Gold, Boston Pro & Cerwin Vega and lots of other small goodies
October 14 2004, 8:40 AM
i have absolutely no clue which wire is which on the ZE disty....why don't you do the write up when you install urs? would be cool to see the wiring involved.
DONATE TO MX-3.COM
October 14 2004, 2:12 PM
I think i have a klze disty wiring diagram Gro. If you want a picture i could email it too you. But great work on the external coil. It`s probally going save people alot of money on disty`s (you were also running on your 5th disty right?)
Klze,CAI,Exedy clutch, HM Engine mounts, HM ss exhaust system,Cobra lowering springs, 18" wheels.
October 19 2004, 3:05 PM
if you do have the klze wiring diagram..pleas send it to me..steve_racine17@hotmail.com
October 19 2004, 6:19 PM
