View unanswered posts | View active topics It is currently November 18 2019, 2:49 PM
Reply to topic  [ 6 posts ]
 30X ABS light
Post 30X ABS light
Does anyone know how to get the ABS light to come off in a Eunos 30x??
September 27 2011, 3:20 AM
Post Re: 30X ABS light
Replace the broken abs sensor or take the light out of the dash.
Just another Mx3 freak :)
Feedback topic: Click
Worklog click
September 27 2011, 3:45 AM
Where is the abs sensor? Does it effect the abs if the light is on?
September 27 2011, 4:28 AM
Hey mate, not sure if you had any luck with this or not, but if you have a Eunos 30x, you might be better off asking stuff about it on the Australian forum, www.teameunos.com
_K_I_R_K_S_ on there should be able to help you, if not others...
'92 JDM Eunos Presso - Zeke
November 06 2011, 6:02 AM
Yes, if the light is on your abs wont work.
There are 4 sensors; 1 on each wheel.
Things are rediculously expensive !!
Worklog click
November 07 2011, 4:06 AM
You should also know that in ABS cars the ABS warning light also comes on to indicate a low voltage situation i.e. charging system. Found that out myself the hard way.
November 07 2011, 10:58 AM
