View unanswered posts | View active topics It is currently July 14 2020, 3:57 AM
Reply to topic  [ 5 posts ]
 Installing an amp and sub
Post Installing an amp and sub
hi guys just wanted to know if someone could help me out a little bit as im new to having my az-3.
I want to install a sub and an amp but im having a problem locating a place to feed the power cable through the firewall?
i dont really want to do any drilling and would prefer using an existing hole. any help or anyone who knows where to locate a whole that would suit?
October 05 2010, 7:19 PM
Post Re: Installing an amp and sub
there are several holes to choose from. Get a flashlight. They will probably have a rubber insert.
October 05 2010, 7:24 PM
could you tell me where these holes might be ive looked for ages all i can find is solid wall
October 05 2010, 7:45 PM
there is one left hand side, past the diagnostics port. There is another one close to the throttle body.
Lay down by on the floor and pull the carpet back a bit from the fire wall. You should see a few plugs.
October 05 2010, 8:18 PM
ok thanks
October 05 2010, 8:43 PM
