View unanswered posts | View active topics It is currently June 05 2020, 1:31 AM
Reply to topic  [ 3 posts ]
 Eunos 800 KL62 PCM (ECU) (ECM)
Post Eunos 800 KL62 PCM (ECU) (ECM)
Hi, I am from Canada and doing a important engine conversion with a JDM Eunos 800 KL-ZE engine (TA5Z Chassis).
Just NEED A GOOD PERSON to find the ECU pinout and I.A.T. / M.A.F. wiring to run the motor.
Ecu P/N: KL62 18 881A
Vehicle: 1994 JDM Eunos 800 (1 ECT Sensor)
Engine: 2.5L DOHC KL-ZE 10:1 CR
Thanks !
'94 Mx-3 GS-R SE, KL-ZE Interprep. (From '96 PGT KL)
1110Kg
-Interprep KL31 Spec.
ported heads, Polished combustion chamber,3 angle vlv job,10.3:1 C.R.,0.020'' O.S.,KL31 cam,-0.007'' heads,Long neck IM,KL31 TB, Hotshot headers,2.25'' exhaust,Magnaflow cat
January 15 2010, 8:11 PM
Post Re: Eunos 800 KL62 PCM (ECU) (ECM)
I wish you luck. Those are hard to find. However, the K8 isn't too far off, and you can run the JE50 MAF. You can have most K8 ECUs reflashed.
January 15 2010, 11:06 PM
Here's just the 95 Millenia 2.5 wiring. Not sure if it'll help
January 23 2010, 12:58 PM
Profile ICQ WWW
