View unanswered posts | View active topics It is currently December 12 2019, 5:25 PM
Reply to topic  [ 3 posts ]
 az-3 parts?
Post az-3 parts?
any information or help would be greatly appreciated.I have a 92 az-3 and have had great difficulty getting the correct parts. When i go to the motor factors, they look under 92 mx-3 1.6 which is a sohc and the 92 az-3 is a dohc. I realise this only matters for certain parts but im never sure if the part they order will fit. I currently need to replace the water pump,Radiator, speedo cable and rear shocks. I got info on the water pump and shocks on this site thanks ozeire! the car has a/c i think it makes a difference with type of rad.got timing belt done 10,000 km ago and should have put new pump in then. I have spent countless hours combing the net and gleaning info from this excellent site.Once again many thanks in advance.
May 02 2007, 7:20 PM
Post
Is yours a 1.5? cos the JDM AZ-3's were.
I think most parts should be interchangable, with any differences, try BG-series 323 parts, or even BF-series.
91 Eunos Presso KF-ZE
89 Nissan 300ZX TT 2+2
90 Nissan 300ZX TT 2+0
May 02 2007, 8:30 PM
Post
yep its 1.5, thanks for the info greatly appreciated.
rory
May 03 2007, 4:18 PM
