View unanswered posts | View active topics It is currently June 03 2020, 7:55 AM
Reply to topic  [ 8 posts ]
 94' Stereo wiring Diagram(with colors)
Post 94' Stereo wiring Diagram(with colors)
Constant 12V+ Blue/Red
Switched 12V+ Blue/White
Ground n/a
Illumination Red/Black
Dimmer n/a
Antenna Driver's Pillar
Front Speakers 5 1/4" Doors
Left Front (+) Blue
Left Front (-) Blue/White
Right Front (+) Blue/Red
Right Front (-) Blue/Yellow
Rear Speakers 5 1/4" Shock Tower
Left Rear (+) Blue/White
Left Rear (-) Blue/Green
Right Rear (+) Blue/Red
Right Rear (-) Blue/Green
Black 94' GS-ZE Sleeper
http://mx-3.com/phpBB3/viewtopic.php?f=46&t=77160
November 20 2010, 4:21 AM
Post Re: 94' Stereo wiring Diagram(with colors)
bulls---! someone delete this post, those colours are WRONG.
Totally impossible.
November 21 2010, 1:32 AM
they were the same as my car? i dont understand how there wrong?.. every wire was the same when i put my new deck in? :S .. sorry to anyone who this caused a problem too lol. was useful for me, thats why i posted..
November 27 2010, 10:47 AM
If you hooked up switched 12v to your speaker, you'll pop a fuse and pop the speaker pronto.
Another impossibility. Do you have a basic understanding of electricity? How do you not see how its wrong?
I have no idea how you hooked yours up, its not that the chart doesn't just have the wrong order of wires, it doesn't have the proper colors at all. I know for sure there are yellow and violet in the harness.
All of those are red, blue, white, green, black. No chance in hell that controls signals for everything... dimmer is orange. ground is black, not N/A. remote is solid blue, not a speaker wire. switched power will be white/red, constant will be solid red. speakers will have 8 different codes, they do not share negative channels or positive channels.
its just so totally WRONG. I'm having problems here, please delete your post.
November 27 2010, 12:34 PM
Just get an adapter harness: so much cleaner and easier to work on when actually doing the wiring, you don't hack up your harness, easy to change radios in the future. The only reason otherwise would be to save a measly $20?
November 27 2010, 2:50 PM
Profile ICQ WWW
i didn't have that choice with my car.
the previous owner mutilated it so bad i had to make a new wiring harness, at least i got to upgrade the wire size =/
November 27 2010, 9:28 PM
True that. Mind you, could always go the wreckers and get the harness from a scraped Mx-3 to fix it.
November 28 2010, 3:08 PM
Profile ICQ WWW
you know, i never thought about that.
i already has some cheap 16ga monster wire sitting around so i just wired it all through, and one of my wires didn't work either so that's probably why i didn't consider a junkyard harness
November 28 2010, 5:34 PM
Users browsing this forum: No registered users and 3 guests
