View unanswered posts | View active topics It is currently July 06 2020, 7:03 PM
Reply to topic  [ 7 posts ]
 How do YOU torque?
Post How do YOU torque?
So say the manual says something needs to be torqued at 12-17 inch lbs.
How do you torque it down? Right at 12? Right at 17? Or maybe in the middle say 14? Or does it really not matter as long as its in that range?
August 12 2013, 6:24 PM
Profile YIM
Post Re: How do YOU torque?
If it's inch pounds i do it in the middle or to the closest multiple of five, just because my TQ wrench is easy to set at denominations of five.
If it's foot pounds I do it right in the middle, both my Mastercraft and Mac one are a PITA to wind up or down but I don't want to torque to the least amount needed.
Daninski wrote:
This is my MX3. There are many like it, but this one is mine. My MX3 is my best friend. It is my life. I must master it as I master my life. My MX3, without me, is useless. Without my MX3, I am useless. I must fire up my MX3 true. I must drive straighter than any Honda driver who is trying to own me. I must own him before he owns me.
August 12 2013, 6:38 PM
I thought so. Thats how i do it as well. In the middle number as possible. Im asking because I just replaced my oil cooler. New OEM gasket. Torqued to spec right in the middle of what that manual wanted but it seems to be leaking AGAIN. I was just curious how others do it. Do you recommend a re torque of stuff after its heated up and cooled down?
August 12 2013, 7:05 PM
Profile YIM
Often times its not just the gasket thats leaking... sometimes its the pressure sensor, or possibly a cracked hosing...
I actually don't torque anything like that acording to the books.. I go by feel with a hand wrench most of the time..
Plus when you torque something with a torque wrench its very important the threads are clean, the bolts screw in and out by hand easy... When the wrench clicks you want it to happen while you are turning the bolt at a bit of a slow consistent speed...
When gaskets come into play you have go back and double check the torque, often times the gasket squishes leaving your first bolt loose..
August 12 2013, 9:57 PM
Depending on the task I usually do it in the middle + quarter/half turn
racycle's Worklog!
http://www.mx-3.com/phpBB3/viewtopic.php?f=46&t=76991
-RIP
Current Toy
viewtopic.php?f=7&t=80470
Please don't tap on the hood. It disturbs the gerbils.
November 19 2013, 2:33 AM
I use the middle for anything with short thread depth, narrow bolts, etc. that run higher risk of being stripped.
Anything larger, with deep threads, I run the "max" torque.
'12 Challenger R/T Plus w/ STP - 3.92 w/ Limited Slip, Shorty headers, SkipShift delete, Clutch Delay Valve delete, Hurst STS, RAM Clutch Adjuster, StopTech 6 Piston Brakes, Sticky Nittos, Tuned
'92 GS 5 spd - Straightneck KL, 67mm TB, MegaSquirt, Coilpacks, 5 lugs, Speed6 brakes, FD wheels, wiretuck, progressive coilovers, shorty headers w/ custom collector, AEM WB, 2.5" straight, Borla XS
November 21 2013, 5:25 PM
I always go just shy of max reason being I've never heard of some thing getting tighter but I have seen torques drop after use from gaskets flattening out or what ever. Be sure to have your toque wrench calibrated as well to be sure it's actually applying the correct torque. As far as stripping the threads I'd rather have them strip while I'm torquing than strip when I'm driving down the road. Go Max or Go Home. :lol:
November 21 2013, 8:34 PM
