View unanswered posts | View active topics It is currently June 04 2020, 3:57 PM
Reply to topic  [ 236 posts ]  Go to page 1, 2, 3, 4, 5 ... 16  Next
 weede`s KL-ZE Supercharger - Megasquirt
Post weede`s KL-ZE Supercharger - Megasquirt
Hello, My name is Jerry and I come from Poland ;)
Here is my 94` Mazda:
2015 SETUP
Engine:
2.5v6 KLZE engine (Full rebuild)
Oil filter relocation kit (custom)
KLZE straight-neck intake
Millenia-S injectors 280cc
Millenia-S Rods with ZE pistions (custom pins)
StandAlone Megasquirt II ECU
Eaton M62 Supercharger with custom bracket
AFR Innovate MTS with Gauge
FPR Turbosmart with custom adapter
MAP Sensor conversion
2,5" exhaust with twin-loop OBX mufler
2,5" ss headers
FMIC with custom aluminum piping
Gearbox
KL gearbox
Mazda KL LSD (torsen)
III straight cut gear PAR Engineering
ACT KL clutch kit w. 6pads
short-shifter
Brakes:
Mazda Xedos 9 brake pump with servo
Mazda 6 calipers with 283mm rotors
Goodridge steel lines
FERODO pads
Suspension
Tokico HP Struds
Ground Control Coilover Kit with Eibach springs
Eibach cambers
Poli-Brush red
Rear and front strud bars
Wheels
Dragwheels DR-23 Rally Bronze 16"
Yokohama AVS 205/50 tires
Dragwheels black screws
Interior
Sparco Torino II Seats with custom rails
323 GTR momo steering wheel
Oil temp, Oil Press, Intake pressure gauges
AFR Gauge Innovate
ALPINE CDE-101R
My White JDM MX-3 ZE
August 07 2010, 11:59 AM
Post Re: 94" weede`s JDMstyle MX-3ZE
O-M-G...
This has to be the best mx3 that I have seen for some time! Very clean and well modded. Wow :)
August 07 2010, 12:40 PM
ditto - nice first post! Sweet mx-3 man, welcome to the forums!
August 07 2010, 1:04 PM
Wow super nice and clean. Where are you located???
August 07 2010, 6:37 PM
He's from poland by the looks of it
August 07 2010, 6:53 PM
clean very clean
It only takes a single voice to start a revolution
August 07 2010, 8:32 PM
thank`s everyone ;)
I`m doing a research about force induction with a Eaton m62 like this:
A plan is to have 250-270hp becouse after that it will be some problems with gearbox ;)
I`ve done a proper list to this modyfication:
- eaton m62 supercharge (i think 0,5bar it will be enough) - what belt will fit?
- mounting kit replace Air conditionf supercharge
- millenia s rods
- millenia s 270cc injectors (will it adequate to about 250hp?)
- slim ntercooler + piping
- smt6 or MS computer
- egt, oil temp. gauge (something else? afr?)
- walbro 255 fuel pomp
Maybe it will be my winter project if everting goes right ;)
August 07 2010, 9:20 PM
You will need to take a peice of string or tape and make a loop and get the measurement that way and get a custom belt.
weede_klze wrote:
- millenia s rods
You dont need rods, the stock rods will hold as long as you have a good tune, that way you dont need to take apart your motor. Milly s injectors will work fine.
Boost, AFR and EGT or oil press are most important.
August 07 2010, 10:39 PM
Thank`s! I`ll still doing some research about this.
KLZE + supercharge sounds insane!
http://www.youtube.com/watch?v=5PTrZJvA ... re=related
August 09 2010, 5:23 AM
Dude! Wow! So nice! 5*
August 09 2010, 2:10 PM
Thats one sharp looking MX3.Love it in white.Keep it clean and stock looking. 8)
August 09 2010, 7:54 PM
I don`t like spoilers at all ;) only exception is mazdaspeed front bumper which is very very rare in europe and corcsport with shipping too expensive
August 10 2010, 3:55 AM
This may be a long shot but I would be willing to look into shipping you a mazdaspeed for an oem like you have on your car (with a lip). :shrug: :shrug: :shrug: :shrug: Just a thought.
August 10 2010, 11:30 PM
Does that sticker say SRT8????
August 11 2010, 12:00 AM
i was wondering when someone would mention that
August 11 2010, 12:22 AM
