Marco's '95GS - Budget restoration, then LPG conversion?
| Author |
Message |
marcdh
Joined: July 26 2006, 3:54 PM Posts: 1397 Location: Belfast -Northern Ireland
 Re: Marco's '95 GS KLZE - Black Beast
johnmx3ze wrote: very nice ride man... does it really help with the filled mounts? Thank you  Yep, as Jesse said, it sure does help keep the ZE under control, it's a cheap and easy DIY mod that really works! I still get wheel hop but that's my shocks and springs letting me down  OutlaW wrote: nice charriot , kind sir Thank you good sir! Perhaps one day I'll take an epic road trip to portugal  projectzemx3 wrote: looks awesome man, i love it. Thank you  I'm very jealous of your big garage and sideskirts! Nifty work with the mx6 booster too  My straight neck intake shall be going on soon!
_________________ Autozam AZ-3 1.5 B5ZE - Sooty 2.0 - Project eco-boost Mx-3 2.5 V6 Turbo 291 BHP 251 lbft @ 8psi - Retired due to rust and back at uni View Worklog
| January 21 2009, 2:55 PM |
Flyer
fowljesse wrote: I want to make that picture into an inspirational poster. Something like AMBITION You don't HAVE to drive a Honda. With some creativity, and work, you could drive a car like this.  Just for you
MrMazda92 wrote: I find Honduh forums more helpful, typically more pleasant too.
| January 21 2009, 3:16 PM |
fowljesse
Joined: March 17 2006, 3:59 PM Posts: 5675 Location: portland, OR
That's EXACTLY what I had in mind! Nice. Marco, what springs/ struts do you have? I thought you had K-sport..
_________________ '93 GS - P&P DE w/ ZE exh. cams/ pistns, KLG4 IM, 65mm TB, MSnS, Phenos, K&N RAI, UDP, Grnd wires, rear batt, filld MM, torq strt, TWM short shftr, Exedy, Lng tube hdrs 2.5" Side exhaust, H&R sprngs, Poly bushngs, strutbars, Alum. crss mmber&tiebar, 22mm swybar, solid links, Direzzas, leather int, Alpine 9805 stereo & alrm, keyless entry, 10 Boston Accoustics spkrs, Prjectrs, Blaster2, CF hood, FG hatch, Lexan
| January 22 2009, 4:13 AM |
marcdh
Nice one Flyer Nope I wish I did, I have an unknown setup, came with the black car. Springs are red (about -45mm), struts look oem replacement. It's very bouncy, so I guess my shocks are effectively redundant  I really want coilovers, just can't settle on which ones, plus I'm in too many pending GBs at the minute to buy them - especially as I may have to front a fair bit of cash for the adjustable cam pulleys GB.
| January 22 2009, 5:39 AM |
projectzemx3
Joined: August 23 2008, 12:09 AM Posts: 1083 Location: Beamsville.
do you have a problem with heat because of your headers not being wrapped?
_________________ NEED PARTS INSTALLED? PM ME!
| January 24 2009, 9:19 PM |
JM1EC-V6
Joined: October 25 2005, 8:35 PM Posts: 192 Location: Chicoutimi, Québec , Canada
nice black beast !!! i love this mx ! congrats !
_________________ '94 Mx-3 GS-R SE, KL-ZE Interprep. (From '96 PGT KL) 1110Kg -Interprep KL31 Spec. ported heads, Polished combustion chamber,3 angle vlv job,10.3:1 C.R.,0.020'' O.S.,KL31 cam,-0.007'' heads,Long neck IM,KL31 TB, Hotshot headers,2.25'' exhaust,Magnaflow cat
| January 25 2009, 4:03 PM |
marcdh
projectzemx3 wrote: do you have a problem with heat because of your headers not being wrapped? Nope not really. Gets a bit hot I guess, but so did my stock k8. My temps usually a little under halfway, I think the vented hood helps a bit  JM1EC-V6 wrote: nice black beast !!! i love this mx ! congrats ! Thanks This weekend I decided to be straight...necked. Hourglassed KL31 TB. Not OTT but a fair whack off, every little helps eh?  Despite having both of these I never really noticed how the plenum and mouths were so different!  Here it is installed. I had to remove the OEM battery tie down and replaced with a sleeker ratchet strap as the bolts were pushing into the 90deg elbow. I think I might move the battery to the boot at some stage. Bit crowded up there.  I went out for a quick blast. Was too wet to get decent traction though. My VRIS wasn't working at first, I had the check valve backwards !  I expect I'll lose a bit of power really due to my probinator VRIS being set for curved neck... But megasquirt can take care of that before too long
| January 25 2009, 4:49 PM |
jamesmx3
Joined: March 09 2007, 12:53 PM Posts: 203 Location: preston, uk
love the purple rocker cover, i read through your other worklog on the 'other site' wondering when you painted the red one, haha.
Looks stunning!
_________________ 1997 1.6 16v DOHC uk spec gs, 17" wolfrace triad, 2.0l probe s/s header magnaflow high flow cat, powerflow custom catback, CAI, zx2 struts w/ -40mm lesjofors springs
http://www.uk-mx3.com
| January 25 2009, 5:15 PM |
solo_ryder
Joined: October 16 2004, 2:01 AM Posts: 6285 Location: British Columbia
Looks AWESOME Marco. You polish your own manifolds? I love the look of the straightneck
Keep up the good work, any pics of the interior of the car?
| January 25 2009, 5:16 PM |
projectzemx3
defiantly straight neck looks so bad a--. easy with RHD tho, check out my worklog, i had to fit a mx3 master to a slim mx6 booster and im STILL not sure it will be able to fit the straight neck. in which case ill buy a curved one. are you going to sell yours?
| January 25 2009, 7:01 PM |
fowljesse
More very nice work! Your engine looks so nice I had my intake exactly the same way before moving the battery. You can just cut your 90° elbow to 45°. I'm going to do the hourglass thing, too, but will also shave the other sides of the bolts. For anyone with LHD wanting a high flow manifold; the KLG4 from '96 626s, and later, flows almost as well as the ZE, and fits. I don't know if you know, but you can bypass the AIC with MS, and the idle won't surge.
| January 25 2009, 7:23 PM |
projectzemx3
fowljesse wrote: More very nice work! Your engine looks so nice I had my intake exactly the same way before moving the battery. You can just cut your 90° elbow to 45°. I'm going to do the hourglass thing, too, but will also shave the other sides of the bolts. For anyone with LHD wanting a high flow manifold; the KLG4 from '96 626s, and later, flows almost as well as the ZE, and fits. I don't know if you know, but you can bypass the AIC with MS, and the idle won't surge. the ports are square too? i thought those were just de's with round ports.
| January 26 2009, 12:28 AM |
solo_ryder
KLG4 IM's have square ports, the heads are oval port.
| January 26 2009, 12:45 AM |
marcdh
jamesmx3 wrote: i read through your other worklog on the 'other site' wondering when you painted the red one, haha. Thanks James  I bought that black car October 07 solo_ryder wrote: You polish your own manifolds? Keep up the good work, any pics of the interior of the car? Thanks Jordan, yea I do, dear god, the effort is a bit ridiculous. Got a few drill attachments that helps speed it up, and a triangular detail sander, and of course the trusty dremel sanding wheel to remove the cast lines. I polished the millenia, so I couldn't downgrade in style by installing a rough straightneck! I'll get some interior pics soon. Not much to shout about, though a few nice features in the works. Non bucket cloth seats though  projectzemx3 wrote: i had to fit a mx3 master to a slim mx6 booster and im STILL not sure it will be able to fit the straight neck. in which case ill buy a curved one. are you going to sell yours? Yea I saw your determined effort, good job! Don't think I'll sell mine, I'm still evaluating which I prefer, and like having both (greedy). fowljesse wrote: More very nice work! Your engine looks so nice I had my intake exactly the same way before moving the battery. You can just cut your 90° elbow to 45°. I'm going to do the hourglass thing, too, but will also shave the other sides of the bolts. I don't know if you know, but you can bypass the AIC with MS, and the idle won't surge. Thanks Jesse  Yea I thought about the sides but my dremel was a bit too fat to do a good job, I'd need an extension thing for it. Bypassing IAC would be great, that thing is always flipping me off! It's something I've read can be done, but haven't researched it at all. How's progress with your MS?
| January 26 2009, 6:44 AM |
marcdh
Well some of you may be sad to see my Straight neck has been replaced again with the curved neck. My 0-60s were worse by .5 of a second, and that annoyed me! Not sure if VRIS being wrong made all that difference? It may come back though when megasquirt is done. In other news I got a Mazdaspeed strut brace  It so far is clearing the millenia IM with some spacers washers on the shock bolts. It would be fine if I didn't have thermoblok spacers, but I do, and I like them too much to remove them.   Here's also a pic of my interior's current state. A few work in progresses going on. You can see the stainless "mx-3" door sills, the brushed alu dial circle, the fiberglassed speaker volcanoes, dubious alpine DVD player replica, guage pods fiberglassed into original trim with a lonely AEM wideband... and an ECU awaiting new megasquirt
| February 07 2009, 3:11 PM |
Who is online |
Users browsing this forum: No registered users and 1 guest |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum
