View unanswered posts | View active topics It is currently July 02 2020, 2:13 PM
Reply to topic  [ 15 posts ]
 Front Swaybar (Feeler)
Would you be interested in a front swaybar?
Yes 92%  92%  [ 11 ]
No 8%  8%  [ 1 ]
Total votes : 12
Post Front Swaybar (Feeler)
I`m in contact with Corksport about getting some front swaybars for the Mx3.
Here`s the mail I got from them today:
'I have looked into getting some swaybars built in the past for the Mx3. We could offer one but I would need to have a few of them ordered up at once to get a run done. Know of anyone else who would want one?
Thanks
Derrick'
So, how many would be actually interested in this?
Gro, Babyblue, jschrauwen, I guess you would be?
This is just a feeler to get this rolling, and I hope you are as anxious as I am about getting more decent suspension goodies for our car.
nope-mx3
April 24 2006, 4:41 PM
Post
that would be cool, but im not too enthusiastic about corksport :?
i would consider it none the less, but wish it was a different company
April 24 2006, 5:08 PM
Post
Just FYI upgrading the front sway bar without a pretty major upgrade on the rear will only cause MORE understeer...
White Line was the one who told me this after inquiring about them making one for the front to compliment the rear they make. They told me their rear is engineered to compliment the GS front already.
April 24 2006, 7:19 PM
Post
I know, but I got about every upgrade for the suspension, and when it was snow here, the car was pretty hard to drive.
The rear end was all over the place at times.
And there is a reason Mazdaspeed made a front sway bar.
I for one would definitely be glad for less bodyroll, and a more neutral handling in the winter :)
Got another email now, and this is what Derrick says:
'Hello,
Well a guess would be in the 190-200 range with end links and other hardware.
Thanks
Derrick '
nope-mx3
April 25 2006, 2:14 AM
Post
come on guys, this would be a very nice addon for our cars.
-nope
April 28 2006, 4:59 PM
Post
Would'nt you need to pull the engine out to install one?
Taras
'92 GS Gray ZE
'05 Gixxer 750
MxWest VP
www.mx-west.com
May 01 2006, 8:59 PM
Post
I`ve heard it`s easier to install while the engine is out, but I dont think it`s necessary.
-nope
May 02 2006, 12:59 AM
Post hey
i got a front strut tower bar from Napa for 35$ and i noticed a diference right away. I mean a bar is a bar come on wheather its mazda speed or corksport.
May 05 2006, 12:01 AM
Post Re: hey
We are talking about the bar thats underneath the engine, between the control arms.
-nope
May 05 2006, 12:51 AM
Post
Hmm, I'm interested, I just don't want to add understeer.
May 06 2006, 11:05 PM
Profile ICQ WWW
Post
There is and old trick to improve the handling used by a lot of mazda racers going back to the 323 Cup series and still used by Protege racer up until the introduction of the BK. That is to just disconnect the front anti roll bar all together or some have made compressable end links. I disconnected the front anti roll bar a few years ago which yielded a couple extra point of the G-pad. As a general rule to achieve that greatest handling with any of the 323 based cars including the mazda BF to BJ, CA & CB & EC chassis (plus US & Au Escort/ Laser/ Lynx and Kia Sephia) Lower the car no more than 1.2" front springs 275-325lb/ rear 450-700lb. Front anti-roll bar none to 20mm/ rear anti-roll 22/24mm solid bar. Note that dampers must be able to control the compression and rebound of the springs. Sub frame connectors and Gacchiri bars are also offer a big increase in chassis ridgity if the class of racing allow them.
May 07 2006, 12:52 PM
Post
i might be intrested in the front bar. i got a 323 GTR Solid rear bar for my rear end 20mm i think i will have to look again. a front would be nice but i dont think its as nessasary, i think the V6 guys would benifit from it more.
May 07 2006, 10:02 PM
Post
i would like a front bar. id rather dial out understeer by picking stiffer rear spring rates to help the rear rotate rather than unhook the front bar.
im sure many people in the past unhooked the front bar but it was probably due to the limited availability of suspension tuning parts. it seems more of a bandaid rather than a fix
my feedback page
BLAZE RED 93 GS
2004 G35 Coupe w/Brembo package
MY 93 MR2 TURBO
mx-3.com sticker
May 28 2006, 3:12 AM
Profile YIM
Post
Taking a look today i believe that Mx3 folks can use 2nd gen protege front sway bars 24-24.5mm range by just changing the endlinks.
not only is it apparent that the subframe is nearly if not identical to BG chassis, with what appears to be 95+ mx3 LCA's added on.
Its worth the time to investigate it, with dual heimjoints i know its fully feasible to make it work. if anyone wants to spend less money go try this.
October 02 2006, 10:31 PM
Profile YIM WWW
Post
heres another thing i pulled off today
http://www.clubprotege.com/forum/showth ... post337333
Using the ZX2 25.4mm/1" bar
October 03 2006, 3:09 PM
Profile YIM WWW
