View unanswered posts | View active topics It is currently August 11 2020, 3:20 PM
Reply to topic  [ 14 posts ]
 Gas/fuel meter doesn't work
Post Gas/fuel meter doesn't work
Why would a gas meter not work anymore ?
The light when I'm low on fuel still works. But the meter always indicates full (i wish it was !!)
Just another Mx3 freak :)
Feedback topic: Click
Worklog click
February 09 2012, 3:57 AM
Post Re: Gas/fuel meter doesn't work
I have a semi related question here.....
Ummm..... do all MX3s have fuel lights that come one when gas is low? I ask because mine has never gone off before....
Daninski wrote:
This is my MX3. There are many like it, but this one is mine. My MX3 is my best friend. It is my life. I must master it as I master my life. My MX3, without me, is useless. Without my MX3, I am useless. I must fire up my MX3 true. I must drive straighter than any Honda driver who is trying to own me. I must own him before he owns me.
February 09 2012, 4:11 AM
You sure it's the gauge and not the sending unit in the tank? I've never replaced the gauge, but I've had to replace the sending unit before, maybe even twice, but the low fuel light is independant from the gauge needle, that seems to be a different sensor.
February 09 2012, 4:29 AM
Profile ICQ WWW
I'd test the sending unit first as well, I've had several fail in other cars.
'12 Challenger R/T Plus w/ STP - 3.92 w/ Limited Slip, Shorty headers, SkipShift delete, Clutch Delay Valve delete, Hurst STS, RAM Clutch Adjuster, StopTech 6 Piston Brakes, Sticky Nittos, Tuned
'92 GS 5 spd - Straightneck KL, 67mm TB, MegaSquirt, Coilpacks, 5 lugs, Speed6 brakes, FD wheels, wiretuck, progressive coilovers, shorty headers w/ custom collector, AEM WB, 2.5" straight, Borla XS
February 09 2012, 4:51 AM
So where could i find the sending unit ? How does it look like?
I've replaced the stock pomp with the walbro, perhaps I messed up the sending unit ?
Worklog click
February 09 2012, 8:09 AM
Did this happen when you were modifying your gauge cluster?
The fuel pump attaches to the sending unit, I haven't personally had a reason to take mine out yet, but I would assume that it is under the rear seat with the pump. :D
February 09 2012, 1:10 PM
Uhh.... it happend some years ago.. can't really remember when.
I just went to a gasstation when the light came on.
Worklog click
February 10 2012, 3:51 AM
Hmm, well that's still not too bad... when my light is steady on I have almost exactly 3.2 Gallons left!
February 10 2012, 6:40 AM
The sending unit is in the gas tank, accessible under the rear seat. It looks like this:
That's for a 323, but nearly identical. That black square box is your floater.
February 10 2012, 11:56 AM
Profile ICQ WWW
you can test the sender by putting a volt meter onto the 2 leads (screws) that the gauge needle uses for signal. with the pump assembly removed from the car have someone move the sending arm up and down while its attached to the harness and the ignition on(car off). voltage ouput between the leads should move up and down with the lever, if not replace the sender, if it does replace the gauge...
March 07 2012, 11:58 PM
Thanks, for the tip
I've replaced both :)
Worklog click
March 08 2012, 6:22 AM
Super old topic bump.
Where did you find this sending unit? Did you get it via Ali Express? searching on what key words?
Worklog click
February 25 2018, 6:13 PM
I got mine from Mazda directly....but we're going back many, many years.
March 15 2018, 2:46 PM
Profile ICQ WWW
https://www.ebay.ca/itm/Mazda-Mx-3-Mx-3 ... rm&vxp=mtr
March 15 2018, 2:49 PM
Profile ICQ WWW
Users browsing this forum: No registered users and 4 guests
