View unanswered posts | View active topics It is currently June 03 2020, 4:38 AM
Reply to topic  [ 3 posts ]
 Speed sensor location and plug pictures??
Post Speed sensor location and plug pictures??
Does anyone have a picture of the plug that goes to the speed sensor? I've got a G trans from a 96ish Probe. Mechanic couldn't figure out why my speedo didn't work, so I took a look last night...and there was nothing plugged in. Found a busted connector, and judging by what little plastic is left, it was gray. 2 pin...looks like it may fit. Red and green wire I believe. If anyone can confirm/post a picture I would greatly appreciate it! *Update* My speedometer works. The speed sensor is the plug on top, firewall side correct? That's definitely not plugged in...
93 GS: KLZE, EBay headers and downpipe, "Custom" Intake, No Name exhaust, 15x7 Enkei Rpf1, Lotek Drops
09 Civic Si Sedan: K&N Typhoon intake, Skunk2 Megapower Cat-back
14 Stryker: Stock as F**K
January 29 2015, 5:43 PM
Post Re: Speed sensor location and plug pictures??
Just to be on the safe side can you take a picture of the plug and post it. Try to show where it is on the harness as well.
January 30 2015, 12:00 PM
It's going to be a while for that. Car is BACK at the shop...broke down 3 days after I got it back...
February 03 2015, 2:59 AM
