View unanswered posts | View active topics It is currently May 19 2013, 2:02 PM
Reply to topic  [ 5 posts ]
 DIY: How to Change Manual Transmission Fluid
Post DIY: How to Change Manual Transmission Fluid
Seeing as how last night I finally did oil and transmission fluid, thought it would be nice to share some info on how to change the MX-3 transmission fluid (PITA without any previous info).
Required:
  • 3L of 75W90 gear oil (Redline is my preferred brand)
  • Fluid transfer pump ($10 from Partsource/Walmart/Canadian Tire)
  • 23mm socket
Instructions:
  • Run the car for about 2km. Let it cool for about 15 minutes. Jack the car up safely.
  • The transmission is located on drivers side of the engine bay. Above the plastic shield is a 23mm bolt, loosen it. It is facing towards the front of the car, and is above a sensor with green wires. This is the fill port.
  • On the bottom of the transmission is a 23mm bolt. This is the drain port. Remove it and remove the fill bolt.
  • When all of the fluid has been drained, replace the drain bolt.
  • Insert one tube of your fluid transfer pump into the fill port, and the other end into your transmission fluid. Pump 3L of transmission fluid in, and replace the fill bolt.
  • Lower the car, and shift through the gears (WHILE THE CAR IS OFF).
Congratulations, you've changed the transmission fluid. It fixed my issue (jerkiness in 1st/2nd). Make sure to read what fluid you need for your MX-3. I'll be uploading pictures and the factory recommendations.
Black 1993 Mazda MX-3 GS - daily driver
Kenwood BT-948HD, MB Quart FX4.100 and ONX1.1000D, Polk MM6501 x4, Polk MM1240
SE interior, MOMO Endurance shift boot, Tomei long shift knob, eBay short shifter
Red 1987 Toyota MR2 - go kart
"If it's crazy you want, it's crazy you get."
September 20 2011, 2:03 PM
Post Re: DIY: How to Change Manual Transmission Fluid
Good write up however,,,you didn't mention where the fill bolt is located maybe mention to dispose of the old oil in an environmentally responsibly manner.
94 MX-6.
September 20 2011, 3:55 PM
Hey can you show me a picture of were the vent is on the G5M-R.
1996 MX-3 KL-ZE with Eunos 800 IM, factory side skirts, 17" rims. "2 Owner my 10th year"
1992 929s 20B-REW Lowered, 17" chrome Millenia rims, custom black interior. "13th Owner 5th year"
2006 Chevy HHR LT "Bought Brand New - East Side Chevy"
September 20 2011, 7:04 PM
Don't mean to clutter but I thought the fill port was the speedo gear hole?
October 29 2011, 9:51 AM
i was gonna mention that too and i think that's just for 4cyl's
October 29 2011, 3:56 PM
