View unanswered posts | View active topics It is currently July 12 2020, 2:24 AM
Reply to topic  [ 2 posts ]
 HEI mod 96 MX-3 V6
Post HEI mod 96 MX-3 V6
96 diagram, modified from the 95 diagram on Probetalk. The resistor is on the green wire instead of the middle yellow wire, that's the only difference between 95 and 96. Carry on with the mod and follow the numerous write ups that are available out there.
Here is the original HEI Mod write up by Gro Harlem found in Probe Talk: http://www.clubprotege.com/wil/howto/hei/index.htm
For his 93 Fowljesse installed the coil directly into the disty, here's his write up; http://www.mx-3.com/phpBB3/viewtopic.ph ... s&start=75
And finally here's one I like because he shows the modual all nicely wired up.
http://www.cardomain.com/ride/633391/8
March 03 2009, 10:52 PM
Post Re: HEI mod 96 MX-3 V6
March 16 2009, 12:45 PM
Profile ICQ WWW
