View unanswered posts | View active topics It is currently February 21 2019, 8:13 AM
Reply to topic  [ 11 posts ]
 KL31/36 CEL checking
Post KL31/36 CEL checking
i searched and searched, i remember something being said on how to check the CEL on the j-spec ECUs since they dont use the CEL on the cluster, i am getting some really bad MPGs lately and i know my O2s are good, not a year old yet, so i need to check it and i cant find how
January 08 2006, 6:43 PM
Post
According to this post it's the same as far as pullig codes.
http://www.mx-3.com/phpbb2/viewtopic.php?t=45272
Here is the procedure (V6 FAQ)
http://www.mx-3.com/phpbb2/viewtopic.php?t=34787
Good luck!
January 08 2006, 7:15 PM
Post
try this thread
http://mx-3.com/phpbb2/viewtopic.php?t= ... d+klze+ecu
January 08 2006, 7:16 PM
Post
Good luck!
i know how to do it with us-spec ecus, i just didnt know what i needed to do extra with the j-spec ones
January 08 2006, 7:20 PM
Post
Good luck!
Well that's good! Now go back a reread what I've posted, because I already answered your question it in the very first sentence. Read the posts in the first link!!!!
Highlight:
Mnemonic wrote:
Note that Jspec ECU's did not come with a CEL indicator so you will no longer have a CHECK ENGINE LIGHT, i know this as i tried to get one to pop up and it never did, you can still check for codes by jumping the pins though (go figure no check engine light signal but it will still work to pull codes).
January 08 2006, 7:28 PM
Post
yea i did, and the second post gave me exactly what i needed without having to sort through unformated posts, jump 10 and gnd (knew that, this is only the 3rd MX-3 i have owned) and THEN jump F and B+ with a LED (check the mods, got a J-Spec KL36 ECU)
Highlight:
Quote:
Jspec ecus have NO Check engine light and require a LED to jump 2 other pins inorder to make a Check Engine light
Quote:
FEN + B+ = KLZE ECU LED
January 08 2006, 7:47 PM
Post
Does the CEL in the dash also flash? Just wondering :?:
January 08 2006, 7:53 PM
Post
nope, thats why i needed to know what pins to put the LED on
January 08 2006, 7:55 PM
Post
OK. thanks. I quess some Jspec do and some don't according to previous posts.
Good luck with your troubleshooting.
January 08 2006, 8:26 PM
Post
so with the led, you just use the 2 wires the have on fen and b? Where do you get a single led from?
1993 MX-3 GS 5 spd, KL-ZE swap, kl31 ecu, 110 amp alternator, Unorthodox Underdrive Pulley, SSautocrome headers, High flow cat, Pacesetter high flow cat-back, B&M shortshifter, Clear Sigs/Sides.
January 08 2006, 9:58 PM
Post
This topic link has good info about LEDs and where to get some.
:arrow: http://www.mx-3.com/phpbb2/viewtopic.php?t=43780
January 08 2006, 10:28 PM
