View unanswered posts | View active topics It is currently April 06 2020, 5:51 PM
Reply to topic  [ 6 posts ]
 Tips on racing with slicks?
Post Tips on racing with slicks?
Going to the track tonite with slicks for the first time. Alllways ran just street tires and avoided the water box like the plague. I hear you want to start your car in second in the burnout box? So Im guessing you roll your front tires in and rip the Ebrake right? Man for alll my driving experience Ive never done this crap! Help?
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
July 19 2008, 11:46 AM
Profile ICQ YIM WWW
Post Re: Tips on racing with slicks?
i'm on drag radials but the same ideas apply... here's how i do a burnout:
roll into the water, set the handbrake
give the tires a quick, short spin. you only need them to turn around once, you are just trying to get the whole tire wet.
pull up a couple feet, just out of the water, set the handbrake again.
rev the motor up a bit... 3-4k. let the clutch out slow till it starts to bog down the motor, then drop the clutch and floor it. eventually you'll drag the back end foreward... or if you dont, let the handbrake down and keep spinning until you are well away from the water. please dont go past the staging line though, lol.
i have always done my burnouts in 1st, but you can experiment and see what works best for you. the most important part is letting the clutch out slow until it starts to grab. if you just rev it up and dump it, you WILL break an axle.
July 24 2008, 5:51 PM
yeah dont past the starting line most tracks Greatlakesdragway by me if you pass it theyll just tell you to take the pit road back inline.
November 18 2008, 3:12 PM
Excellant advice. I'll use it in the spring when I go to the track.
November 18 2008, 9:39 PM
Yeah it important to let the clutch out slow I broke a axle once lol.
May 21 2009, 5:50 PM
grabyskyh, your a moron.
May 10 2010, 12:01 PM
