Page 1 of 1
[ 6 posts ] |
Author |
Message |
xTUCK3Rx
Joined: June 04 2007, 10:50 PM Posts: 7 Location: Up state NY
 Autocross car setup
I have a '92 Mazda MX-3 V6. Its pretty much 100% stock. I am wondering what a good set-up is for the car as far as tire pressure, camber/caster, toe-in, and other basic adjustable stuff to get the best handeling out of my car while still keeping it in stock class. I know it has a lot to do with driver preference but just basic areas to start with for the way the car is. Thanx in advance.
Cody
August 20 2007, 11:09 PM |
PATDIESEL
Joined: August 13 2001, 2:01 AM Posts: 4476 Location: Atlanta, GA.
I would keep it pretty much how it is setup from the factory. Stock toe is fine at 0, camber only has a slight adjustment and is at its most negative from the factory (usually). I would get an alignment, change as many of the suspension bushings as you can for newer ones to take the slop out. Drive it as much as you can b/c seat time makes the most improvement in your time. As for tires I would use Falken Azines. They seem to be the most sticky street tire you can get and stay in stock class. I use them and they work pretty well for me in auto-x. I'm in SM class though.
August 21 2007, 11:28 AM |
xTUCK3Rx
ok thanks for the help. But I thought tires didnt take you up a class so you could have racing tires if you wanted to?
August 21 2007, 6:31 PM |
ElectricEnergy
Joined: August 15 2006, 12:37 AM Posts: 489 Location: Saskatoon SK, Canada
R tires will put you into modified class with most clubs IIRC. I found my stock mx-3 to be competitive at autoX but I was severely limited by tires. I plan to get some Azinis in the near future like patdiesel said.
I haven't tried racing with my ZX2 struts and H&R springs yet, but I imagine it will make a huge improvement.
I am also curious about optimal toe/camber settings since I will be getting an alignment in the next few days here. I heard that as little as an 1/8th of a degree can make a difference for toe.
 KL-ZE Swap - OBX SS Headers - 2.5" Exhaust - Falken Azenis Tires - H&R Springs - ZX-2 Struts - CAI - Front & Rear Tower Bar - AWR Motor Mounts - 100hp wet shot (yet to be tested)
August 22 2007, 1:53 AM |
PATDIESEL
Toe in makes the car corner faster, toe out makes the car better at straight line performance. However, you drive the car everyday right? Why make it a bear to drive everyday for a once a month auto-x by adding toe in. You'll be steering all the way down the highway, no rest and constantly correcting the drifting car... I honestly doubt toe in will make a difference for someone with at least a couple years experience in auto-x.
August 23 2007, 3:11 PM |
ElectricEnergy
You make a good point. No point in wearing out my tires for a couple hundredths of a second around the track anyway. I'll just get it allgned to stock specifications.
August 23 2007, 9:35 PM |
Page 1 of 1
[ 6 posts ] |
Who is online |
Users browsing this forum: No registered users and 1 guest |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum
