View unanswered posts | View active topics It is currently July 10 2020, 11:35 AM
Reply to topic  [ 24 posts ]  Go to page 1, 2  Next
 YOUR 0-60 TIMES??
Post YOUR 0-60 TIMES??
Guys, bring some of your setups and post in this topic your 0-60m times...
Compact Gladiator
"Do not follow the path, instead; go where there is no path and leave a trail"
WWW.GEOCITIES.COM/NEWFLOW81
September 08 2004, 1:26 PM
Post Re: YOUR 0-60 TIMES??
not fast enough yet :D ;)
September 08 2004, 1:59 PM
dude u got a tight webpage! :2thumbsup:
but as for 0-60.. meh i'm slow.. last time i checked it was mid 6's. is that average?
92 Autozam AZ3
September 08 2004, 5:59 PM
<img src="http://memimage.cardomain.net/member_images/7/web/211000-211999/211008_144_full.jpg" alt=" - " />
if you can figure out what is what in this you'll have your answer..bte if somebody got the answer to that let me know..I know I3 is the 1/8th but not sure about the others
RIP 400whp ZE-T MX-3
September 08 2004, 6:35 PM
I1 is your 60ft, 2.175. Sam,i think hes asking for 60ft times since he wants to see slips, not 0-60mph
92 MX-3 RS,
Racing Mazda turbo kit. 451 WHP @ 25 psi
12.1 @ 117 mph w/318whp
http://www.cardomain.com/memberpage/652555
September 08 2004, 7:49 PM
thanks man..how about I2
September 08 2004, 8:32 PM
thanks SAM BAKER. Im still working on that site. And if you can provide any info to enrich my website, be my guess.
Thanks guys
Compact Gladiator
September 10 2004, 12:24 PM
actually, he didn't say he wanted to see slips. he said setups.
and the 0-60 on my old RS was about 10 seconds. lol.
Sold my 95 RS "Little Peanut" but she will never be forgotten. :(
September 10 2004, 2:10 PM
maybe I2 is 330ft???
September 10 2004, 2:13 PM
I know but if you would have read my post carefully you would have noticed that i posted that above time slip because I didn't knew what the "I" meant and what the 0-60 was.
BTW my set-up is on my first page of cardomain on the bottom..just too lazy to post them, here
September 10 2004, 6:54 PM
[b] actually, he didn't say he wanted to see slips. he said setups.
BTW my set-up is on my first page of cardomain on the bottom..just too lazy to post them, here [/b]
What made you think I didn't read your post carefully?
I see the slip you posted and, yes, the first "I" is 60' time. 0-60 is never on a 1/4 mile slip that I've ever seen.
September 11 2004, 7:53 PM
Post
I dont think that 0-60 times will be that impressive b/c of the FWD traction issue..anyone with power will have trouble hooking at low speeds thus not a good 0-60 but still a fast car...unless you have lots of suspension work and an LSD... :lol:
Laser Red '96 GT-[SIZE="1"]12:1-IBeams-10k RPM-EXT. OIL PUMP-COLT ONE-OFF CAMS-CUSTOM LONGTUBES-SHEETMETAL IM-BUILT HEADS-125 SHOT-PAR 3/4 GEARSETS-MFACTORY LSD-ETC..SHOULD BE A FUN RIDE..[/SIZE]:thup:
http://www.cardomain.com/ride/542054
August 01 2005, 2:36 AM
Post
7.6 seconds @ 120 bhp at the engine ...
March 29 2007, 7:45 PM
Post
With my open diff setup & 245/50-R16 tires a Hybussa could only pull 3 cars on me in a 1/6th mile from a dig. This was with the clutch slipping.
We are going to the track this coming Friday with the LSD setup. My 60's with the smaller tires was 2.4sec. as they just went up in smoke if I tried to launch. Since the larger tires have been on I don't have new times yet. If I can pull a sub 2sec. 60' with the boost turned back up to 26psi...we are targeting sub 7sec 1/8th mile at tripple digit trap speeds. The new Griffen aluminum radiator should be a BIG plus as I blew a 3" long crack in the end tank of the stock radiator during the winter...things got a little to hot for it to handle...even with redline water wetter, a 180* thermostat, and the fan on constantly.
March 31 2007, 12:06 AM
Profile YIM WWW
Post
just under 5 secs for me. for 0-60 mph.
April 01 2007, 9:34 AM
