View unanswered posts | View active topics It is currently August 15 2020, 4:30 AM
Reply to topic  [ 32 posts ]  Go to page 1, 2, 3  Next
 1" or bigger Master Cylinder?
Post 1" or bigger Master Cylinder?
I'm looking to do a full on brake upgrade over the winter and I would like to look into a new master cylinder. The Mx-6 Master Cylinder looks longer but the diameter is the same. Does anyone know of any other options?
October 10 2013, 8:50 PM
Post Re: 1" or bigger Master Cylinder?
Millenia master cylinder is bigger.
October 10 2013, 9:31 PM
Profile ICQ YIM WWW
The Millenia master has a 1" piston, but the ports are on the other side and the length of the push rod and stuff are different. I have been planning on making it work when I do the refurb on the Black Beast, but it's not plug and play at all.
October 11 2013, 12:29 AM
You will have to rebend your brake lines so they would bolt up on the other side of master cylinder.
October 11 2013, 12:51 AM
Profile ICQ YIM WWW
Ive heard rumors of using 929 parts, might be worth some research
**edit with a quick search:
viewtopic.php?f=20&t=78680&hilit=929
October 11 2013, 7:39 AM
Thanks for the information everyone
October 13 2013, 11:32 AM
929 1" master on an RS booster will work. should be plug and play.
I am with Wytbishop on my milly 1" master convo on the GS. I have not played with it enough yet to install it, but have noticed the reservoir will need to be swapped to the GS one also, as it sits at a funny angle in the milly.
October 15 2013, 12:16 PM
I installed the milli master. It is a bit of a pain tho. You reuse the old reservoir. You have to trim some of the housing from one of the sides to fit the mounting bolt. Take the banjo fittings off, bend the lines(carefully) to the other side of the master and screw the lines in directly. That's pretty much it. Now that I read what I wrote down, it doesn't seem very complicated, LOL. :lol:
Knowing you've spent too much on your car,
yet, you still want to keep modding. -priceless
boosted_bullet
93 Honda Accord LX - Wrecked
95 Honda Del Sol Si - Stolen
92 Honda Accord EX - Parted out
2000 Toyota Celica GTS - Cracked block and broken differential teeth
93 SE - ATX to MTX, work as always in progress
01 Toyota Celica GTS - DD
Worklog to be up soon, still... ...
October 19 2013, 2:57 AM
Sorry about the late reply but thank you everyone for you input. this among other things will be getting done soon and i will make a write-up for it.
January 05 2014, 4:31 PM
Please share with some pics
Just another Mx3 freak :)
Feedback topic: Click
Worklog click
January 05 2014, 4:58 PM
absolutely
January 06 2014, 9:19 PM
Ok, will do give me a cpl days, it's pretty cold and windy around here the last few days...
boosted_bullet
January 06 2014, 11:43 PM
Did you have a chance to take some pictures.
Worklog click
January 12 2014, 5:09 PM
Okay, I finally got to them, while trying to figure out why shes not starting....
Here is the lines re-routed to the other side, I shoulda got a picture of more of the line, but all I did was carefully bend them.
Here is the pass. side area where I cut.
And the drivers side.
boosted_bullet
January 12 2014, 10:44 PM
Okay, I didn't cut the drivers side, but from them the pic it looks like I did. I thought I did for a sec. :shrug: :lol:
boosted_bullet
January 12 2014, 10:48 PM
Users browsing this forum: No registered users and 5 guests
