View unanswered posts | View active topics It is currently August 10 2020, 3:54 PM
Reply to topic  [ 3 posts ]
 Intake Vacuum Lines
Post Intake Vacuum Lines
Hey guys i have a MX6 V6 that someone removed the stock airbox on. Im getting a vacuum line engine code so i found that i have a line missing that goes to some sort of air sensor. Anyone know where this is supposed to run to?
ThanksImage
93 Mx-3 GS
5 SPD Conversion
Worklog at
viewtopic.php?f=46&t=54796
April 24 2017, 4:50 PM
Post Re: Intake Vacuum Lines
There should be a vac line going to your intake from that nipple I believe. https://www.mazdaforum.com/forum/mazda- ... 537/page2/
April 27 2017, 10:13 PM
That vacuum line diagram is so hard to follow since i dont know what each part is called... There is a module that has 3 vacuum ports and one with 2 ports.
93 Mx-3 GS
5 SPD Conversion
Worklog at
April 27 2017, 10:19 PM
