View unanswered posts | View active topics It is currently June 03 2020, 6:12 AM
Reply to topic  [ 5 posts ]
 Car wouldn't start
Post Car wouldn't start
Im truck driver and parked my car in the company yard for couple weeks. Today I came home, started my car and drove to store to get a couple items. I came out later and car wouldn't start like totally dead. I used my booster pack and it wouldn't start, another guy tried to give me jump start and still it wouldn't start. Finally my brother came and we push started it. I drove back home and shut it down my driveway, went to restart it and it started up just fine, several times.
I wonder what was wrong? Battery is fairly new and I drove it from company yard to the store good 20 miles or so, battery should've had enough time to recharge.
i think when I come home next time I'll load test battery and maybe check starter, remove it and take it auto parts store to check it on their test bench. Anything else I can do?
December 11 2016, 11:51 PM
Profile ICQ YIM WWW
Post Re: Car wouldn't start
Check the battery wire at the starter for corrosion.
January 08 2017, 9:54 PM
I would check the ground connection as well as the ignition switch.
February 08 2017, 3:40 AM
If you didn't hear any noises sounds like ground. Otherwise could be sticky solenoid, a whack with a hammer can dislodge it temporarily.
View Worklog
February 08 2017, 4:20 PM
I load tested battery and it showed that it was not holding charge, recharged it and so far its been able to start the car.
February 10 2017, 8:37 PM
Profile ICQ YIM WWW
