View unanswered posts | View active topics It is currently June 03 2020, 5:00 AM
Reply to topic  [ 1 post ]
 K8/KL distributor
Post K8/KL distributor
Ok first, my setup :
03 Protege5 with Jdm KLDE swap. Modified 96 mx3 harness. KLK1 ecu.
The swap is almost completed but I have no spark.
I do have injector pulse though, so I guess my ECU is fine. I do have Vref also.
I checked my distributor harness for powers and grounds, all fine.
My ecu requires a 96+ 5 pin ICM (actually 6 pins but one serves no purpose as it lacks the 2nd hall effect sensor)
My question :
Knowing that pinout if different on both, is there any reason I couldn't use a 94 mx3 distributor?
Or worded differently, would a 1994 mx3 distributor work on a 95+ 626/millenia, if I repinned the connectors?
If so, why? Are trigger inputs the same from the ecu?
92 MX-3 RS RIP
94 MX-3 RS Black
Project car, hybrid B5-ZET build-up.
October 06 2016, 12:49 PM
