http://mx-3.com/phpBB3/
Mazda mx3 1.8 v6 not starting unless fuel pump is turned off
http://mx-3.com/phpBB3/viewtopic.php?f=15&t=82053
Author:  Chartin81 [ April 25 2016, 3:12 PM ]
Post subject:  Mazda mx3 1.8 v6 not starting unless fuel pump is turned off
So having a problem had to put an external cool and igniter on my car and ran fine now its not wanting to start in less I unplug the fuel pump will idle very low plug the pump back in and will sometimes run sometimes just die changed the fuel pressure regulator and no change in thinking injectors just want to make sure it's not something else instead anybody have this issue? Thanks
Author:  Dragon1212 [ May 19 2016, 12:34 AM ]
Post subject:  Re: Mazda mx3 1.8 v6 not starting unless fuel pump is turned
Did you turn the distributor at all? sounds to me like you are out of timing. My car ran like that after a engine swap. If you haven't moved it, then don't touch it yet.
This is the HEI mod found in the FAQ Section right?
*This one*
Author:  MX_Sid [ May 25 2016, 3:37 AM ]
yeah, that's the HEI mod.
Yo, chartin81, when is the last time you changed your fuel filter, or ran injector cleaner? It may be silly to ask, but sometimes...
Anyways, have you checked your wire connections? That would be where I started diagnosing starting problems.
Also, fuel shouldn't flow with the pump unplugged. Sounds like fuel line blockage increasing pressure and reducing flow. It could be a clogged or seized injector. Either way, something is holding your fuel pressure high enough that the the car can still run with pump disconnected...
Author:  Chartin81 [ May 25 2016, 6:47 AM ]
Actually think it was a little of both took fuel lines down an d blew them out along with injectors an d adjusted dist some an d it's running not not perfect but better so still working on it thanks for y'alls help
Page 1 of 1 All times are UTC - 5 hours [ DST ]
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
http://www.phpbb.com/
