View unanswered posts | View active topics It is currently May 23 2018, 8:25 AM
Reply to topic  [ 10 posts ]
 Spark plug for KFZE
Post Spark plug for KFZE
i have a kfze and i forgot what is the bet plug to use?
Is it the heat range 5's or 6's
I know ngk v powers,,,,is there a better plug
If any1 knows the plug full number code thats great.,,,,i kinda got my plugs mixe up and lost the originals so im using klde plugs at the moment
February 08 2010, 1:29 AM
Post Re: Spark plug for KFZE
I was using the k8 plugs, worked well for me until I flooded the engine with water.
-hec
February 08 2010, 5:01 AM
k8 standard densos or ngk
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
February 09 2010, 10:50 PM
would it be any benifit of using kl plugs?
February 11 2010, 7:32 PM
The issue with KLDE plugs in a KLZE is that they would get hit by the pistons. a KFZE might experience the same problem.
February 11 2010, 8:22 PM
Profile ICQ WWW
it was my understanding that all kl engines are non intereference engines. I know the klde, and kl08 are non intereference.
February 11 2010, 9:47 PM
Non-interference as in the valves won't hit the pistons if the timing belt snaps, but won't take into account spark plugs that are longer than normal...
February 11 2010, 10:04 PM
Profile ICQ WWW
so long as he matches the plug to the proper engine he should be fine, I have heard good things about the diamond fire plugs but have not used them myself as of yet. The stock plug has a projection of 1.5 mm as for heat range I am not to sure what best suits the kfze. The diamond fire plug number is; E3.48 if your interested.
February 11 2010, 11:55 PM
What would be the best plug and gap for a KLZE eng?
1994 toyota supra single turbo
1994 Mazda MX-3 KL-ZE
If god owned a car... It would be a supra!!!
February 15 2010, 8:52 PM
I used NGK Iridiums. Get them for the Probe FS 2.0L 4cyl
February 15 2010, 9:34 PM
Profile ICQ WWW
