View unanswered posts | View active topics It is currently July 02 2020, 7:25 AM
Reply to topic  [ 20 posts ]  Go to page 1, 2  Next
 looking for ZE input on fuel management
Post looking for ZE input on fuel management
OK guys I have spent I don't know how many hours reading and reading here, Probtalk, MX6, and so on trying to find a resolve and have been unsuccessful. As some may know I have purchased a 94 GS with a KLZE. The motor is all correct KL 31 heads, cams, and block. My hang up is it only dyno'd at just under 160whp. with the headers, bored TB, CIA, lightweight flywheel, and a proper curve neck IM it should have been more in the 170 - 180 range. First thing I have noticed is the CIA is a bit undersized with reducers from the VAF down to the pipe and stepped back up to the TB. BUT it should still have done better than that.
Well looking over some things it is running a KL85 ECU and a KL02 Vaf (95 only MX-6, 626), OK, i thought DE mapping on a ZE that would cause it. SO I have come to a couple of possible scenarios to fix the mapping and get the rest of the power out of the ZE thats being bottled up inside. It runs great the way it is other than every once in a while it likes to idle around 1100 rpm for a minute or so, and there is a saying that "if its not broke then don't fix it", but I am anal, and this is what I need input on.
Currently it is running a KL85 and a KL02 VAF with a curve neck IM
1- I could switch to a KL31 ECU and back to the GS VAF (Ideal situation), but would require a couple things and with the curve neck there would be a couple of timing issues but would be better than running the DE mapping. But then I could eventually relo the master cylinder res. and run a straight neck as well then it would be perfect with no issues.
2- I could chip the KL85 and see how that goes. This seems to be the ONLY solution to most reading on other forums, but IMO they don't run 100% and they all run very rich. This is the cheapest solution though.
3- My other thought was to go stand alone or piggy back, but this is my DD and should remain so, so I think going stand alone is out of the question. But a good piggy back unit would resolve the issues as well and have more adjustability on my end to get it a good dyno tune.
Any thoughts? I am "kinda" new to the ZE thing and would appreciate any good direction.
Food for thought - I don't care about emissions I live in an area that I do not have to go in for smog tests :) lucky me. I don't think this means anything really but I am averaging 23 to 25 MPG highway but it does have a standard GS trans, 3100rpm @ 60pmh sucks the gas.
December 30 2011, 2:08 PM
Post Re: looking for ZE input on fuel management
Modding the MX-6 booster and fitting the straight neck manifold is not that big a deal. The worst part of that whole thing was getting the booster out of the MX-6 in the junkyard.
With the straight neck manifold, KL31 ECU and JE50 VAF you'll be in great shape.
December 30 2011, 3:13 PM
Depending on how much care was taken with the swap... do the VRIS work?
December 30 2011, 3:48 PM
Oh yes, the VRIS kicks in quite nicely, but it does seem to come on a bit late in the RPMs.
I am leaning that way as well with the KL31 and JE50, I just needed some conformation :) I did hear that there was an issue with the fan relay but that should be an easy fix. there is actually a second coolant sensor wired up that this ECU does not recognize I guess. It is from the old ecu that they had on it, a chipped K8 ecu?
The swap was done by a shop from what I understand, but that doesn't mean a lot. It is very cleanly done though, even the cruse control works :)
I think I will have to do the ECU/ straight neck swap and brakes at the same time then, perhaps this spring. Straight neck, ECU, master, and while i am at it 2 piston front calipers ;)
Thanks for the input guys
December 30 2011, 4:05 PM
How was the A/F reading for the dyno?
December 30 2011, 5:45 PM
Profile ICQ WWW
Hey Josh, I have an extra kl07 ecu and a JE50 VAF....... I could ship them to you to test :shrug: .
Have you done a compression test???
One other possibility could be that you have a 31 head, 31 cams, Millenia intake, with a DE block..... However, that alone should net you above 160.......
Also, if your having a little hiccup around 1100 you could have either some lost spark or a slight timing issue...... (I'm thinking distributor timing????)
Just some thoughts.....let me know on the ecu\Vaf.
December 30 2011, 6:14 PM
Josh you didn't mention the exhaust, is it the stock K8 cuz if it is that's where your restriction would be. Swapping to a KL31/36 ECU and JE50 VAF would be easy for starters as well.
December 30 2011, 7:34 PM
I agree with the others... go for the KL31/36 and a JE50 vaf and you should gain the most.
Do a proper tune up (fresh o2's, good sensors, no leaking vacuumhoses etc)
Just another Mx3 freak :)
Feedback topic: Click
Worklog click
January 02 2012, 3:36 AM
i have a probinator chip that was in my 94 mx3 ze with curved neck/je50 intake im selling. it might be a cheaper/easier option then tracking down a j-spec ecu... have a look at my thread in the for sale section if your interested...
January 02 2012, 12:19 PM
is there any codes ?? you may be in DAIG mode causing loss of power ?
my engine light was on because of my O2 sensors ( but the bulb was burnt ) -- i could feel the loss in power so
i scanned it and came up with the code I then replaced the dash light bulb and it was then on :( .. i also replaced the o2 sensors and power was back up after i reset the ECU
just a thought for youre situation
Terry
Red96'Mx3 KL-ZE 2.5, CAI, full 2.5'' exhaust,cat delete, black stock rims polished lip, cross drilled brakes, (aftermarket bumper with halo foglights-Needs work) .
http://www.cardomain.com/id/whitete
Previous rides
Purple94' Mx3 K8-ZE CAI, Exhaust, plugs,wires
Purple95' Mx3 K8 american, CAI, Exhaust, plugs, wires,cap/rotor fuel pump, short shift,
Black 94' Mx3 i4 Stock ( hit by dear )
January 02 2012, 2:41 PM
No there are no codes, and the light works. Car runs great except for a high idle every so often. It was just strange to me that it only dyno'd at 160 ish WHP, but finding out that it is running a stock 95 DE ecu I think that is where the problem is. The KL85 ecu that it is running is specific only to the 95 KLDE MX-6 and 626, as well as the VAF that it is running.
I have a A/F meter I just may hook up to see where it is at. maybe its a bad O2.
January 03 2012, 2:03 PM
I would be very interested to see what affect changing the ECU and VAF has on the dyno numbers. To me 165 doesn't seem too far off. If it's rated for 198hp and you figure 20% loss isn't unheard of...165 is in the ballpark.
It will have some implact...5-7hp I expect, but 170ish would be pretty close to optimal for a stock ZE. The highest number I've ever read for a stock ZE is Whisper @180hp I think it was and that to me was hard to believe.
January 03 2012, 2:42 PM
Well if it was stock I could see 160. 160 is close I would be happier at 175. I have see other dyno graphs of stock ZE's dyno at 175WHP on DE mapping :)
It has headers, light weight flywheel, ported TB, 2.5" exhaust, CIA... I would expect it to be just a touch higher. I think with a new CIA and the proper fuel mapping for a ZE it would be a lot better.
I think I am going to source out a proper KL31 and JE50 VAF and see where it goes from there. worst case is I will piggyback the KL85 ECU and install a MAP for better adjustability.
January 03 2012, 2:59 PM
Wait you bought Whisper's car didn't you...must've been someone else that I'm thinking of with that number.
Ported TB is worth a couple, but lightened flywheel and CAI aren't going to get you any power just better response. 2.5"/2.25" exhaust are pretty well a given on any ZE install so that's not going to make much difference from anyone else's numbers.
With the KL31 and JE50 I think you'll see 170. I bet that's what I'd pull. I've never put it on a dyno but that's what I would expect. Let us know what you come up with.
January 03 2012, 3:05 PM
Yes I did,
I will let you know what I come up with, running DE mapping on a ZE is good for the short term and will run just fine, but is not correct for a high output motor like the ZE and it needs to be more precise. Especially when running US grade fuel on a high comp motor.
January 03 2012, 3:26 PM
