View unanswered posts | View active topics It is currently June 03 2020, 4:29 PM
Reply to topic  [ 14 posts ]
 KL31/36 speed cut removal
Post KL31/36 speed cut removal
have searched and searched, havnt found what pin or wire i need to cut to get rid of it
September 13 2005, 11:09 PM
Post
I had posted and had seen a couple of posts aboput it, i did it myself but not sure if it works. We would need to use the search to get those posts back, it was sorta specific on what pun..i think pin 7a or something..i forgot... its actually in the online shop manual and it states which pin is the speed sensor.
-hec
September 13 2005, 11:16 PM
Post
With the KL31/KL36 ECU label facing upwards go to the 22 pin plug (farthest on the right), top row, fifth pin from the left.
September 14 2005, 12:31 AM
Profile YIM
Post
will this will simply remove it ?
with no side affects and the speedo will still work correctly ? :shock:
September 14 2005, 2:31 AM
Post
http://www.mx-3.com/phpbb2/viewtopic.php?t=41776&postdays=0&postorder=asc&&start=0
I tried this in my car and all it effects is the speed limiter. There are no other side effects. As you can see in this post, I was worried about that too. The only side effect is feeling your car go to nearly 140MPH!!! You are in redline territory at that point.
IanL gave me the confidence to do it. I have a 93 and he said that the diagram for the 93 showed it as a black/white wire that ran to the pin that I thought it was. I have a picture that I will post up of the wire I cut in relation to the plug.
93 GS KLZE Straight Neck (Parked)
Green Turd of MOCA
Car Domain
September 14 2005, 8:33 AM
Post
1993 Wiring Diagrams
The wire is Black/White like ccreech mentionned
1988 MR2 S/C :D
September 14 2005, 8:42 AM
Post
I wanna try it after my klze engine is in...
Not very confident this is ok to do..
find it a little hard to believe it's that easy..
Anybody else done it ?
Any side affects ?
September 17 2005, 6:20 AM
Post
ya I posted the good wires on the mx-3quebec club..some of done it without side effects..remember though that the color of the wire will change with years. (92-93 are the same though)
RIP 400whp ZE-T MX-3
September 17 2005, 10:04 AM
Post
1988 MR2 S/C :D
September 17 2005, 11:12 AM
Post
anybody had any problems with doing this ?
September 17 2005, 11:24 AM
Post
Eric, where do you come up with those great pics and diagrams. I need to archive things like that ..... can't trust it all to memory ... LOL
September 17 2005, 2:24 PM
Profile YIM
Post
just a screenshot form the wiring diagrams I posted earlier... :D I originally got the diagrams from Steve-o :P
1988 MR2 S/C :D
September 18 2005, 9:33 AM
Post
http://www.mx3er.com/Info.htm
kiwi's site..all the wiring diagram are there..They were really helpfull to me when I did megasquirt and ignition upgrade. Save them and keep them close, you'll need them ;)
September 18 2005, 10:05 AM
Post
Did it today....works great...no side effect so far.
Took the car to 130 MPH with ease and it was still pulling. :D
September 18 2005, 11:14 PM
